Dana 70? or Dana70-HD
Old Apr 15, 2010 | 02:53 PM
Budgreen's Avatar
Default Dana 70? or Dana70-HD
what's the difference? besides $300 more for gears?
I need to put gears in mine since the pinion stripped on me
is there a way to tell the difference? believe the build tag on the truck just lists as a 70. it's a 93 w350 dually rear.
Old Apr 15, 2010 | 04:51 PM
tltruckparts's Avatar
all dana axles have the size on the bottom right corner wedge on the pumpkin. it should say d70 on it. if its an hd 70 i believe itll say d70hd but i could be wrong. what size are your axle tubes
Old Apr 15, 2010 | 09:17 PM
Budgreen's Avatar
beats me...
I can poul them tomorrow.
looked at summit website and they had gears in stock so I drove over there to buy them and what the website didn't mention was they were in stock in the warehouse in az can't get them here till next week.. and I need this thing on the road 2 days ago. going to look for a whole rear this sunday when I have time.
Old Apr 16, 2010 | 06:41 AM
oldgrey90's Avatar
the difference is the hd uses a larger inner pinion bearing. the case is different it is made narrower because it uses larger side bearings like a 80. as far as the ring and pinion i do believe that they are the same. if you have it apart and the side bearings and races are 3 series its just a 70. if they are 4 series then its an hd70.
Old Apr 16, 2010 | 07:56 AM
Budgreen's Avatar
Thanks for that info. I'll be gutting it tonight. first time i'm tearing into an axle.. so I get to learn gears and locker at the same time haha.
Old Apr 18, 2010 | 09:50 AM
440ctd's Avatar
good luck bud let me know if you need any help
Old Apr 18, 2010 | 10:25 AM
i really hope you got the right tools to set up a ring and pinion and you understand fully how they work. the slightest bit of being of will make a catastrophic failure
Old Apr 18, 2010 | 11:02 AM
12vcummins96's Avatar
if not use house paint when you start to shim it up to see how far the gears are meshing
just dab some house paint on the ring gear and roll it around youll see if its to much or not enough also make sure to replace the crush washer and put the correct preload on the pinnion bearings
Old Apr 18, 2010 | 11:55 AM
NadirPoint's Avatar
A good gearhead doesn't need a dial indicator to "feel" the right backlash, either.
Old Apr 18, 2010 | 12:00 PM
ya but thats probably someone whos done ring a pinion gears for years or at least numerous times. not someone whos never done one before
