hx35 vs hx40
Old Apr 14, 2010 | 11:18 AM
motown's Avatar
Default hx35 vs hx40
how much better is the 40 over the 30 is it worth the swap r should i just by a after market i'm runing stock head gasket 4 now
Old Apr 14, 2010 | 11:24 AM
tltruckparts's Avatar
i liked my hx40 for what i needed it for. alot of people run the hx35/40 hybrid. you pretty much gotta look at it in terms of cost. pick up a used hx40 for 5 or 600 bucks, or go buy an aftermarket for 1200-2000
Old Apr 14, 2010 | 11:29 AM
motown's Avatar
I just want to keep my heat down once i put in my new inj. 90's or 140's still trying to decide
Old Apr 14, 2010 | 11:38 AM
RIGGLE21's Avatar
just installed a hx40 on my 24v and noticed that the egt ran alittle bit higher at lower rpms...but it helps once the turbo lights....I am running 485hp injectors with it and egt are in the normal range all the time
Old Apr 16, 2010 | 11:46 PM
jkidd's Avatar
not all hx40's are created equal. the hx40 has several different compressor sizes and turbine housings. the super40 is pretty much equal to the s300g/superB the regualr hx40 will not slow as much air and often come with a larger/laggy housing.
Stox5225
May 18, 2015 06:01 AM
cummaprt704
May 9, 2015 04:09 PM
xmedina
Wanted To Buy (WTB) - Used
Mar 2, 2015 08:51 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
BIG SOCHA
Oct 23, 2014 11:01 PM
