Want to go faster!
Old Apr 14, 2010 | 09:14 AM
12valvecory's Avatar
Default Want to go faster!
just got my new truck and i put #6 Plate in it FF and everything turned up. It would smoke alot but its just not fast like i cant even burn the tires out so what do i need to do i turned the star wheel back and dosent smoke as much but still is not fast. I thought about moving the plate up some but i mean what will help. Ive got about a 1000$ to spend so what next.
Old Apr 14, 2010 | 09:21 AM
94 12valve's Avatar
what exactly did you turn up on the truck?
Old Apr 14, 2010 | 11:08 AM
Shea@L&N Performance's Avatar
FormerVendor
Get dome gauges if you don't already have some then bump the timing up to round 16
Old Apr 14, 2010 | 11:36 AM
like i cut the line to the waste gate. afc ff #6plateff and those 191delivery valves and i got gauges and it runs pretty hot will timing make the temps go down.
Old Apr 14, 2010 | 12:25 PM
captain_stabbin's Avatar
its running hott cause you have 191dv's and stock injectors
Old Apr 14, 2010 | 01:30 PM
85_305's Avatar
Being Evaluated
Huh.. a 7k lb diesel dually wont burn it's tires. Son of a b*tch imagine that.
But anyways with the few mods in my sig I can lite up the tires on the right pavement and right clutch popping in 3rd gear. With 5 people in the truck. And 1,070 lbs of sand bags over the rear tires.
Ask me how I know...
Old Apr 14, 2010 | 01:57 PM
Red_Rattler's Avatar
High Tech Redneck
Because you broke it too...
Old Apr 14, 2010 | 02:23 PM
85_305's Avatar
Being Evaluated
Ah touche', my commonrailed friend. I beg to differ. I see it as, the cummins broke itself
Old Apr 14, 2010 | 02:24 PM
FormerVendor
Bumping the timing should make your egt's go down a little bit. Aftermarket turbo and injectors would help alot
Old Apr 15, 2010 | 05:00 PM
Threesixty's Avatar
If you just want to go faster...
I don't see anything about a 3k/4k Governor Spring Kit (GSK) in your descriptions.
Heh... ever think of just buying corvette or something?
