1st gen turbo
Old Apr 12, 2010 | 09:44 AM
Levi Miller's Avatar
Default 1st gen turbo
ok guys i am wanting to get a good turbo for my truck nothing like super expensive butt i also dont want a cheap one i just want a good after market turbo for my truck any suggestions thanks
Old Apr 12, 2010 | 10:05 AM
NadirPoint's Avatar
Super 40.
Old Apr 12, 2010 | 11:15 AM
big bad diesel 416's Avatar
Site Sponsor
i was happy with a 60MM wheel upgrade
Old Apr 12, 2010 | 11:20 AM
1st genny nut's Avatar
hx35 best 216 dollar upgrade ever
Old Apr 12, 2010 | 12:20 PM
tltruckparts's Avatar
an hx35 is a really week upgrade though. especially if you plan on running injectors and all fuel upgrades. id go with an hx40 at the minimum. or if you got the dough to drop 1300-1500 bucks on a turbo get a phat shaft or a super b or something along those lines. remember you get what you pay for
Old Apr 13, 2010 | 09:37 AM
how much would the 60mm wheel cost
Old Apr 13, 2010 | 10:52 AM
the wheels run anywhere from like 100-150 bucks i believe. but then you need to get it machined to clear the wheel IIRC and you will also need to have the shaft rebalanced so your probably looking at 4-500 said and done to do it the right way.
and even with that, you still cant go over about 30 pounds of boost without it being worthless. then your getting out the turbos map and just sending hot air into the engine and it wont gain you anymore power
Old Apr 13, 2010 | 11:24 AM
Site Sponsor
100-150 bucks when i bought mine from gillette diesel it was 250.00 + shipping
Old Apr 13, 2010 | 11:29 AM
NadirPoint's Avatar
The GDS 60mm upgrade is $250 and comes complete with a new housing:
Upgrade Compressor Housing & Wheel combo (60mm inducer) for 1991.5-1994 Turbochargers
It is a fine upgrade for up to around 300hp or 30psi. It just depends on what your power goals/needs are.
Old Apr 13, 2010 | 07:28 PM
TTipsword's Avatar
need a 83mm turbo emaculator herd those things work pretty good.
