Fire Extinguisher Location
Old Sep 12, 2007 | 09:48 AM
cloker12's Avatar
Default Fire Extinguisher Location
I have a 97 xtended cab 2500 and have been wanting to put in a fire extingusher but I want to put it in a place where it is easy to get to when needed but out of the way so your not running into it when you don't. Any ideas would be appreciated, Thanks
cloker12
Old Sep 12, 2007 | 10:00 AM
Nitelord's Avatar
I have mine mounted on the floor, center of the hump. sits right beside the 4 wheel selector. It's easy for either driver or passenger to get too. It's basically dead space for me, having the cup holder folded out all the time.
Old Sep 12, 2007 | 10:50 AM
06 DIESEL's Avatar
I have mine in the center console in my 06, I also had it in there on my 01.
Old Sep 12, 2007 | 12:19 PM
Benjamin's Avatar
Bombardier
i had mine mounted between the seats under the window in my truck. my center console was never in the up position so it wasn't in the way.... that won't work for an extended cab..... how about on the hump behind the front seats unless the extended cab is is constantly packed.....
Old Sep 12, 2007 | 01:15 PM
shortmansyndrome's Avatar
all 3 of my tow trucks had them on the hump by either the 4x4 shifter or trans shifter. never got in the way actully became a good place to dry out my gloves in the winter.
Old Sep 12, 2007 | 01:35 PM
Uncle Bubba's Avatar
I must keep bigger ones then most of the other guys here. I mounted mine, one on each side in the bed so that they could also be accessed by others if needed. I have them mounted to the sidewall of the bed in front of the wheel humps. With the tool box back there it leaves just enough space and is dead space anyway.
Old Sep 12, 2007 | 02:33 PM
06 DIESEL's Avatar
Here is a picture of mine
Old Sep 12, 2007 | 03:07 PM
Dont get defensive...but, what are you going to do with that?
Using that would be like spittin on a forest fire....JMHO.
Old Sep 12, 2007 | 03:10 PM
cashwheel's Avatar
I like between the drivers door and seat on the floor, easy access as you bail out and never in the way, plus it keeps things from sliding out from under the seat and falling out when you open your door.
Old Sep 12, 2007 | 03:42 PM
06 DIESEL's Avatar
I only got one because I had a calliper sticking on my 01 and I had to drive home with it sticking. It was getting really hot driving around town so I picked up a small one in case it got to hot on the way home. I did not have to use it so I just keep it there in case something happens. If I thought I would need a bigger one I would have it. For now it makes me feel better but I agree that it is small, but better to be able to slow the fire down than not have anything. I will get a bigger one eventually but for now it works.
"give:"give:
