What to do what to do???? next step?
Old Apr 11, 2010 | 06:18 PM
hereismylife's Avatar
Question What to do what to do???? next step?
With my mods I have what would you do?
I have a option to run a hx40 pro 60/76/18 or the stock turbo.
I use this as a dd and run the 1/4 miles through the summer?
Looking for the most hp with fuel only.....
thanks
Old Apr 11, 2010 | 06:44 PM
zach_west's Avatar
i'd go with an hx40
Old Apr 11, 2010 | 06:47 PM
Make sure that HX40 has the upgraded stronger shafts.
Old Apr 11, 2010 | 07:06 PM
Question
Originally Posted by zach_west
i'd go with an hx40
Why and can I reach top hp with the mods I have?
Which size shaft are you talking about? Would you use the xh40 though?
Last edited by hereismylife; Apr 11, 2010 at 07:06 PM. Reason: Automerged Doublepost
Old Apr 11, 2010 | 07:16 PM
85_305's Avatar
Being Evaluated
An hx40 is decent.. a REAL hx40 is around 40hp over a stock turbo, but if you are looking to go FAST-FAST, I'd go bigger than an hx40.
The hx40 are great turbos and HAVE a tough shaft. Though if you hvae a few bucks to spend there may be better ones for going super fast.
Old Apr 11, 2010 | 07:21 PM
It is the xh 40 pro. It has the billet compressor wheel. Shaft is 11mm
What boost level will achieve the 40 hp increase?
Old Apr 11, 2010 | 07:58 PM
85_305's Avatar
Being Evaluated
Honestly I'm not sure. Wait for someone more knowledgeable to pipe in. What size exh housing, what size wheel and how many blade?
Old Apr 11, 2010 | 09:31 PM
stock or xh40?
xh40 pro has 60/86-76/64 18 exhaust 7 blade billet compressor wheel
Old Apr 11, 2010 | 10:33 PM
Hammer's Avatar
Joe...
ANY of the HX40's are out of their compressor map above 40psi.
The ability for making more boost pressure does not mean it will provide efficent power.
Also,you should run the 16cm exhaust housing for the best spool on a HX40.
I have seen HX40's go into the mid to high 400's for power on fuel alone and they are a great turbo for someone on a budget.That being said they are known to break their shafts and blow the covers off with too much boost pressure.Most guys who run them pin the covers for longevity and are careful when they lift off of them.
Old Apr 12, 2010 | 12:49 AM
Question
Originally Posted by Hammer
Joe...
Are you talking about the hx40 or the hx40 pro?
The one I have is a wastegated turbo that started in production in 2007. This is not the standard hx40 model.
The shaft is a 11mm and is alot bigger than the hx35
