Afc spring kit?
Old Apr 11, 2010 | 10:47 AM
dan33klein's Avatar
Default Afc spring kit?
what do the afc spring kits you can buy do?
there really cheap and they say there for the 215 pumps and trucks with the 16cm housing?
minimal smoke under acceleration and good response?
just didnt know if they are worth the 50$
Old Apr 11, 2010 | 11:16 AM
94 12valve's Avatar
if you have 1 of your old gov springs just use that. It works very well
Old Apr 11, 2010 | 05:13 PM
85_305's Avatar
Being Evaluated
what does it do though?
Old Apr 11, 2010 | 05:41 PM
94 12valve's Avatar
its a stiffer spring than the stocker but also allowes full travel with out binding up.
In other words it will take more boost before the afc arm begins to move.
Old Apr 11, 2010 | 05:49 PM
85_305's Avatar
Being Evaluated
so this is a good thing? Is it a worthwhile, noticeable mod?
Old Apr 11, 2010 | 05:58 PM
94 12valve's Avatar
yes, less bottom end with the same top end
Old Apr 11, 2010 | 06:23 PM
85_305's Avatar
Being Evaluated
Less bottom-end is a good thing?
What does it do for mileage? Anythign?
Old Apr 11, 2010 | 10:45 PM
dan33klein's Avatar
yeah i can see it being better, it does let the truck fuel so hard down low and put the fire out. but once the turbo lights its gone? i do have my stock gov springs. which one should i use?
Old Apr 12, 2010 | 05:59 AM
94 12valve's Avatar
once the charger lights the foot will move out of the way, if you have it moded ( grinding the barrel and the washer flip). When you take the afc appart use the gov spring that is the same size as the afc spring.
Old Apr 12, 2010 | 06:52 AM
85_305's Avatar
Being Evaluated
Oh that does make sense. So in other words my truck is fueling way to much for the little amount of work being done?
thanks for the explanation
