2001 cummins fast idle
Old Apr 11, 2010 | 12:17 AM
Farmboy 2.0's Avatar
Default 2001 cummins fast idle
So the other day it was cold in the morning and i didnt have my truck plugged in. So when i went out to start it and i let it run for about 30 seconds and made sure there was oil pressure. I ran it up to 1000 rpm for about 45 seconds and then let out and it went back to normal idle speed and went back in the house. A couple minutes later it idle up to 1200 rpm and i went out and stepped on the brake pedal and it went back to normal. Then it did it again alittle later. I know the 3rd gens have this feature from the factory. But i didnt know that the second gens had this too is anyone familar with what im talking about? Sry for the long post
Old Apr 11, 2010 | 12:21 AM
How long have you had the truck? Its possible there was a Smarty on it at some point (which would leave the high idle), or its have been flashed with updates at a dealer.
Nothing to worry about - its a good thing.
Info about it is here: http://dodgeram.info/tsb/2001/18-019-01.htm
Old Apr 11, 2010 | 12:26 AM
Yeah i was excited when it did it. Ive hade the truck since 2006 or so. I dont think it ever had a smarty on it it was a one owner before i got it. They said it was never souped up. And ive never had it to the dealer. But i did try a smarty out the a few weeks ago for about an hour would that do it?
Old Apr 11, 2010 | 12:34 AM
Yes thats what did it. When you remove the Smarty, the performance mods go away but this feature stays.
Old Apr 11, 2010 | 05:52 AM
Jazz's Avatar
x2 on What the good Dr. says I don't know if it will ever get cold enough but you will also have the 3cyl warm up
Old Apr 11, 2010 | 12:46 PM
RAW's Avatar
RAW
I had new software installed into my ECM from a factory dealer. It will rev upto about 1100 RPM when it is cool out, and a few times it has done the 3cyl. warm up. Sounds pretty weird, but works very well.
Old Apr 13, 2010 | 11:06 AM
GuyWithA24Valve's Avatar
How much did it cost to have that done?
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Sep 20, 2015 10:52 PM
Daylon
Aug 23, 2015 11:01 AM
LittleBuck
23
May 21, 2015 06:06 PM
