ICP sensor?
Old Apr 10, 2010 | 08:57 PM
Dieselpuller's Avatar
Default ICP SENSOR
Hey folks
I have an unusual starting problem. Well, maybe not unusual for a 6.0! Anyway, I have an 04 1/2, 75,000 miles, 4" exhaust, AirRaid cold air intake, AMSOIL by pass oil filter and an edge platinum I only run on 2 when towing my 5th wheel. I mainly use the pod for additional gauge readouts.
Sometimes after driving a while and then letting it set and sometimes coming out first thing in the morning, first start of the day, it turns over but won't start. While cranking I get full oil pressure on the gauge, have good voltage, I change the fuel filters every year, run cetane boost and conditioner, and so on. Everytime this has happened all I do is disconnect the batteries, wait a few minutes, hook them back up and after cranking a couple times it fires right up and runs beautiful. It doesn't miss, run rough, there are no oil leaks and I'm a maintenance nut.
I read that an ICP sensor can go bad and keep it from starting. I checked the sensor, no oil pushing through, but the info I read said an ICP sensor can go bad and not necessarily commit a DTC. What to do? Anyone else have this problem? There is no pattern in how it happens, i.e. light driving vs. heavy driving, just setting and so on. Thanks for any help you can offer.
Old Apr 10, 2010 | 10:27 PM
bab213202's Avatar
yea i am kind of having the same problem. still havent figured mine out yet either. only i am getting a oil leak down on my bellhousing and cant find the source. but you cant see hardly anything on that 6.0 engine. let me know if u figure somthing. thanks
Old Apr 21, 2010 | 08:59 PM
mlinder's Avatar
Try unplugging the icp should fool the computer in firing the injectors. If it works unplugged change the icp and pigtail.
Old Apr 23, 2010 | 11:41 AM
Lange503's Avatar
when i had my 06 6.0 it would start when the ICP went out, just wouldn't run worth a **** and cloud up the street with black smoke
also, try clearing your code right before you start it, see if it does anything? worth a try atleast
Old Apr 23, 2010 | 05:05 PM
Mdub707's Avatar
Show me a 6.0 that doesn't have a wet bellhousing. I've yet to see one in person.
Try what mlinder said.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Svonasek
Oct 8, 2015 10:25 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mr. Walkway
May 11, 2015 10:49 AM
robbyS
Apr 16, 2015 02:22 PM
