6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Smokes white on driver side
Old Apr 9, 2010 | 05:24 AM
90dodgectd's Avatar
Default Smokes white on driver side
Hey I just picked up a M1008 with the 6.2 and the truck runs great. Starts right up but smokes white out of the driver side tailpipe. It smells like diesel so i dont think its rings, I think its a stuck injector. The smoke might clear up alittle as the truck is run but it still smokes. Any ideas?
Old Apr 9, 2010 | 06:37 AM
wildbill's Avatar
Loosen each injector line, just enough to make the engine miss. As soon as it quits smoking, you found the sticky injector. I'd have em all rebuilt as soon as practical so your not chancing flooding the engine with diesel.
Old Apr 9, 2010 | 11:54 AM
2MuchJunk's Avatar
I would say you have a bad injector on the one side. And I would do the same test as above and get them rebuilt.
Old Apr 10, 2010 | 12:10 AM
Woody35's Avatar
better rebuild them or else your going to have a hole in your piston
Old Apr 11, 2010 | 08:28 PM
90dodgectd's Avatar
Loosened the injector lines today and #3 is the culpret and maybe #7 too. Is there anything I can do to maybe free the injector up so its not stuck? Can I pull it out and soak em in something?
Old Apr 11, 2010 | 09:51 PM
2MuchJunk's Avatar
I would not try to fix it I would have them rebuilt. If A injector fails it would get expensive quick and with the amount you would probably drive the truck they would last forever.
Old Apr 14, 2010 | 08:39 PM
90dodgectd's Avatar
Put 2 quarts of ATF in the tank and the smoke is clearing up. Only smokes on start up then it clears up. Just got tags today and drove it to the gas station and filled up and put another quart of ATF and some Diesel Cleen. Oh and I also found out it has a death wobble . Steering stableizer will be here next week.
Old Apr 14, 2010 | 09:39 PM
2MuchJunk's Avatar
Atf will loosen them up I would say you still have one laying down but if it works run it. Death wobble thats no fun.
Old Apr 19, 2010 | 09:16 PM
HAYMAFIA's Avatar
use two cycle oil instead of atf. less detergents
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
wpg6.5
Mar 22, 2015 12:38 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
