more power from the 6.7
Old Apr 8, 2010 | 09:52 PM
smokeseeker22's Avatar
Default more power from the 6.7
i have a 2008 dodge 2500 with a smarty programmer right now i was wondweing what the next step in power would be... im stuck between the h&s black maxx the edge or even going to injectors... does anyone know which chip will work best with the smarty for power and i would also like to see a little more smoke seeing as i have to floor it now just to see a little puff... thanks
Old Apr 8, 2010 | 09:55 PM
bobcat67's Avatar
well i think you'll only be able to run the edge being as it's a pressure box, not an OBDII one whereas the blackmaxx is
Old Apr 8, 2010 | 10:13 PM
Are you running a DPF Delete?
Old Apr 9, 2010 | 08:31 AM
ya i am running a 5'' strait pipe. the smarty deletes the dpf. is there any other moodules that can be run with the smarty other than the edge
Old Apr 9, 2010 | 10:53 AM
Lil Dog's Avatar
More power than the SMarty? The latest revision has a 200 hp bump on SW9... Not sure how much the stock injectors are good for but it would be turbo time anyway..
Old Apr 9, 2010 | 03:39 PM
my09cummins's Avatar
The only ones that you can really stack with the smarty would be edge, mp8, or the power puck. But on a slightly modified truck you are pretty much pushin it to the max with your smarty. I know its a lot of money but next step unfortunately is fuel mods and turbo
Old Apr 9, 2010 | 03:51 PM
FarmDiesel's Avatar
I have a smarty and an edge... With the smarty on sw7 and the edge on the 80 horse setting... It really doesnt smoke that much.
Old Apr 10, 2010 | 05:28 AM
dodgeram082500's Avatar
before I personally went to much more power I would throw some head studs in the mix I do and I run the mp8 with the blackmaxx pretty regular either way your going to need to build for the horse power you are gunna make/fuel/air/studs
Old Apr 11, 2010 | 09:50 AM
tjoneal2's Avatar
does any one know how to make a smoke switch on a 6.7
i have straight 4" edge with attitude smarty airaid cold air egr delete emm. delete turned up but not alot of smoke do yall know about making a smoke switch with this
Old Apr 13, 2010 | 04:12 AM
yeah, it consist of tapping into the map sensor with a switch and a 100 ohm resistor, i'll try and find out which two wires to tap into tomorrow
