Codes
Old Apr 8, 2010 | 07:44 PM
OIL CAN's Avatar
Default Codes
Ok if anyone can help me out!!! Jus got the turbo code P0237 and 1693. I know that the 1693 go's with the 237 but can anyone lead me in the right direction. My truck is exactly as in sig and my pump wire is not tapped. Also the truck has the factory HX35 on it. I'm not familiar with the turbo boost sensor!! THANKS in advance.
Ok... the more i read on here is leanin me toward my comp box???? I think i may need to unplug comp and go from there... OK heres my next question am i gonna be able to use my comp again and maybe put on a stealth plate???????
Old Apr 8, 2010 | 08:07 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
Try clearing the codes and see if it comes back. If it does then try unplugging the map sensor at the block. Leave the Comp plugged into the harness just unplug at the block. I used to run my Comp like that and loved it.
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
