Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
RED POWER
Old Sep 11, 2007 | 02:40 AM
LOGANSTANFORTH's Avatar
Default RED POWER
IH tractor power increases.
You should have a American Bosch M100 Pump on the DT436. Remove the 4 bolt cover on top and turn the screw in 1 to 1/2 revolution.
966's will find an increase with a turbo from a 10/14/15 66 series tractors, the only thing is you need a donor tractor for turbo, lines, fittings, manifold, and the fuel tank and brackets. this is all worth about 45 horsepower. the fuel tanks are different, the turbo models have a notched tank so the exhaust stack will miss. you will also need to either cut a hole in the hood or find another 66 turbo series hood to fit it. Becareful on a turbo on a D436 I don't think they had piston oil coolers on them like the DT414/DT436/DT466. I picked that little tidbit of information from another site, Logan.
***MIND YOU THAT THOSE TRACTOR REAR ENDS WE'RE MEANT TO TAKE ALOT OF HORSEPOWER SO DONT GET STUPID WITH IT***
Ill have some stuff for you deere guys tomorrow when i get time.
Old Sep 11, 2007 | 06:34 AM
06 DIESEL's Avatar
Thumbs up
I thought that you were talking about the magazine, but this is still some great info. The rears in those will not take that much HP, but after a quick change you can put some serious power to the ground. Here is proof that paint doesn't pull also.
Here is the final standing for this past season. You have to scroll down on the left to see it but he is in the 12000# Farm Stock class. Scott Hoene IH 1066 Known as the "Dirty Dan" Second in the points in the state of IL
http://www.itpapulling.com/
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
