Cummins into 1983 Chevy 1ton Dually
Old Apr 7, 2010 | 03:26 PM
Crippled1's Avatar
Cool Cummins into 1983 Chevy 1ton Dually
Those of you who have swapped in a 1st gen Cummins into a Chevy truck with the hydro boost brake system, have any of you utilized the existing cummins power steering pump to power up the chevy hydro brake booster and power steering box on the chevy with positive results?
Old Apr 7, 2010 | 03:47 PM
big bad diesel 416's Avatar
Site Sponsor
pm
tltruckparts
Old Apr 8, 2010 | 02:36 PM
DennyT's Avatar
Yeah a good friend of mine did it (hotdawg4bt on other forums) He used it and it worked great. It would lock up 38's no problem...............
Old Apr 8, 2010 | 09:37 PM
dieseldawg's Avatar
the power steering and booster work fine no problem at all!!
Old Apr 8, 2010 | 10:04 PM
tltruckparts's Avatar
ive done it. its simple.
there is a little diagram for you. orange hoses are pressure hoses.
for your other hoses, i just used fuel line and hose clamps with a y adapter for the return. works great and no problems!
Old Apr 30, 2010 | 01:36 PM
Edahall's Avatar
tltruckparts,
1. Did you have to swap power steering pumps or did the original Dodge power steering pump have adequate capacity to handle the hydroboost?
2. Did you fabricate your own pressure hoses? If so, where did you buy the hoses and what kind of clamps / fittings you used?
Thanks,
Ed
Old May 3, 2010 | 10:35 AM
Edahall's Avatar
bump
Old May 4, 2010 | 06:37 PM
FastCR's Avatar
I used the stock cummins one. First I T'd the return, but the power steering was sucking so I brazed another return onto the reservoir.
It works. I wouldn't say its amazing, but I've got a lot of other things going on. The only real problem i have is my idle is so low I don't have much for steering when not on the pedal.
Old May 4, 2010 | 07:16 PM
Edahall's Avatar
Thanks for the reply. Did you notice any braking improvement over the old system.
Also, I understand that the newer model Dodges use hydroboost braking. I wonder if their power steering pumps put out more output and if we could use it on our trucks.
Old May 9, 2010 | 05:25 AM
Bill H's Avatar
i just took the back off the GMC pump and put it on the front of the Dodge pump.....they both were the same make and it works fine
Jackthesmallengineguy
Nov 12, 2017 01:25 PM
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
Big Sal
Apr 19, 2015 03:59 PM
Oct 16, 2014 07:10 PM
mtedrick4
Oct 13, 2014 09:25 PM
