Starter Trouble
Old Apr 7, 2010 | 12:44 AM
Boondockers's Avatar
Default Starter Trouble
I've got a 98.5 cummins, sometimes when I try to start it it just goes click then if I try again most of the time the starter will engage. The truck has 162,000 miles and it looks like the orginal starter, is it going bad? If so, will I be better off o get a new starter or get it rebuilt? Thanks all Boondockers
Old Apr 7, 2010 | 01:13 AM
coyropin's Avatar
first off check the batterys and connections, if they are all good check you starter relay, its in you fuse panel under the hood they are just a regular looking relay, if they are good then the chances are the starter is bad, its cheaper to get one rebuilt if you can but the fastest is buy a new one
Old Apr 7, 2010 | 01:37 AM
How will I know if the relays are bad will they look burnt?
Old Apr 7, 2010 | 01:53 AM
coyropin's Avatar
yeah burnt or have some one turn it over and feel if it clicks
read thru this post it will give you some good info
https://www.dieselbombers.com/24-val...-problems.html
Old Apr 7, 2010 | 06:07 AM
Jazz's Avatar
It's sounds like the starter contacts. If so it's a pretty easy job to rebuild yourself
Maybe this will help http://www.fostertruck.com/dodge/default.htm
Old Apr 7, 2010 | 06:58 AM
Whit's Avatar
Site Mascot
times 2 what Jazz says
Old Apr 8, 2010 | 11:18 PM
Thanks for the info will check that out and let you all know how I made out thanks again
Old Apr 9, 2010 | 03:59 AM
turbo20psi's Avatar
Heres a good site also.GOULD GEAR AND ELECTRIC INC.
Old Apr 9, 2010 | 10:47 AM
01quadcab's Avatar
just replace the contacts like they said. It's an easy job. Just did mine 2 weeks ago.
Old Apr 11, 2010 | 05:02 AM
Thanks all contacts did the trick. Only took me about 20 minutes in and out job wrapped up. Next up and coming project six inch stacks
