Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
NEW AT PULLIN NEED ADVICE
Old Apr 6, 2010 | 10:22 PM
cummins94's Avatar
Default NEW AT PULLIN NEED ADVICE
I HAVE A 79 FORD THAT IM MAKIN A PULLIN TRUCK AND WAS WONDERIN IF THERE WAS ANY ADVICE TO WHAT I COULD DO TO MAKE IT BETTER, I HAVE THE TRACTION BARS WITH A 94 MODEL 12V AND A ALLISON 1000 WITH A STAND ALONE CONTROLLER BUT I HAVE ANOTHER THRED ABOUT HORSEPOWER ADJUSTMENTS IF ANY ADVICE CAN BE GIVEN ID APPREICATE IT ALOT WANT TO MAKE IT RIGHT THE FIRST TIME THANKS IM NEW SO HI EVERYBODY
Old Apr 7, 2010 | 07:21 AM
biged681985's Avatar
what class would you want to pull in? another thing a puller needs is suspension blocks. most places requires a min of 1 inch of suspension travel. do you have a stack on you truck? if not, then your going to need a stack, or an elbo on your regular exhaust to direct smoke/parts up wards in case somethin goes wrong.
Old Apr 7, 2010 | 10:28 AM
cummins94's Avatar
yes i have stacks two 6in black ones, the truck is lifted when i got it and i swapped out the suspenion kits to make it a 6in lift before i new i was going to try and sled pull. will the 6in lift hurt the truck if i left it on there and tryed to pull with in? because the back of the truck has blocks to raise it to the right height but the front was new leaf springs because it has 2001 f350 axles under neath it so it aint sure bout the lift?
Old Apr 7, 2010 | 11:12 AM
Red_Rattler's Avatar
High Tech Redneck
Lift is def not gonna help... Driveline angle is your enemy! I hope you don't have stacked blocks on the rear as well, that's a big no no...
Old Apr 7, 2010 | 11:44 AM
Horsedriver's Avatar
Default lift blocks
Lift blocks will only add wheel hopping leverage to axels not braced ie ,tractionbars,also if you hook for fun ,one needs the exaust elbo and stops? A reg
Old Apr 7, 2010 | 12:10 PM
theres a reason u dont see alot of lifted trucks pulling. no matter what, u have the same hitch hieght as all the rest. u have more suspension flex also, the driveline is at a greater angle, and will cause alot greater stress on the u-joints
Old Apr 7, 2010 | 06:43 PM
cummins94's Avatar
so get rid of the lift and put back to stock height and what do i need to do for the blocks for the suspenion for that mimnail drop? do i need to just make a custom set of traction bars? but if i go back to stock height what after that?
Old Apr 7, 2010 | 10:18 PM
here is a thread on suspension blocks https://www.dieselbombers.com/transf...ion-stops.html
Old Apr 8, 2010 | 11:09 AM
cummins94's Avatar
thanks that thread was very helpful. thanks for all your alls advice
Old Apr 8, 2010 | 10:14 PM
np man. feel free to ask. alot of us on here pull
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
