Which Turbo
Old Apr 5, 2010 | 11:45 PM
tltruckparts's Avatar
Default Which Turbo
well i decided to hold off on twins right now and focus more on the p pump swap for my truck. so instead of doing twins i want one good charger for now. i dont want to spend 1500-2000 bucks so im more in the 1000-1200 range. what do you guys reccomend thatll do my good for now, but make a killer top turbo for compounds later down the road? i was thinkin a super b. phat shaft 62, s300, etc. what do you guys reccomend?
Old Apr 5, 2010 | 11:56 PM
Shea@L&N Performance's Avatar
FormerVendor
either one of the three would work great both as a single and as a top charger on a compound setup
ArizonaRedneck's Avatar
i wouldnt know tltruckparts but man you sure here alot of good things about the three you mentioned especially the s300 as a single or twins
Old Apr 6, 2010 | 06:00 AM
94 12valve's Avatar
Try to find a used 62 /65/13SS , that would be one of my top choices for a good twin set up
Old Apr 6, 2010 | 09:06 AM
is that an htb2 turbo?
Old Apr 6, 2010 | 11:15 AM
94 12valve's Avatar
it would be HTT's " Street Stock" charger. the htb2 is the 64mm compressor
Old Apr 6, 2010 | 08:55 PM
well im looking around and i am seeing prices for those 62/65/13ss turbos going for 1600+ used. thats a little out of my budget. unless someone has got a smokin deal
Old Apr 6, 2010 | 11:03 PM
94 12valve's Avatar
I'm fresh out. Like I said that would be one of my top choices, the cheeper route would be an hx40. Just don't push it too hard
or if you don't mind doing a little extra fab work a he351cw would work well
Old Apr 6, 2010 | 11:22 PM
well i already have an hx40 on it. its the 56mm version though. would i better off to do the 60mm upgrade on it. or should i just sell it and get a new charger
Old Apr 7, 2010 | 05:58 AM
94 12valve's Avatar
upgrade to the 7 blade comp wheel and throw a ht3b under it. They can be had cheep and there a very popular choice for twin setups.
