Torqshift Swap 4x4 Question
Old Apr 5, 2010 | 10:19 PM
dan33klein's Avatar
Default Torqshift Swap 4x4 Question
ok guys, im putting my buddys 5r110 torqshift tranny and transfer case behind my twin turbo cummins 12v motor in my dodge truck. my question is, how can i wire up the electric transfer case? im sure i could wire it. but i guess a better question is what should i do for a switch? buy a replacement one off ebay or something? and try mounting it in my truck? also, where is the controller located? doesnt the swtich run to a box in the fender or something then go to the transfer case?
any help is welcome!!
Old Apr 6, 2010 | 02:01 PM
Karls03's Avatar
Diesel Power Mag did a Fummins recently and used a stand alone computer for the trans. I don't remember if it was the 4 speed or the TorqShift.
Better put some go fast parts in that trans before you stuff it in there or you're going to be taking it right back out. For that matter, I'd say skip the middle man and grab a built aftermarket TorqShift and converter. I'm thinkng that compound turbo Cummins is making a pound or two of torque.
Old Apr 6, 2010 | 03:23 PM
dan33klein's Avatar
see thats the thing. im just trading him my 5spd for it. this is not costing me a dime!!!! but to have my driveshafts cut and balanced thats it!!. it has a stand alone module already. he has a cummins in his ford. pcs is the name. it already has a suncoast tripple disk convertor. im calling brians truck shop today to see if i can drop a few parts in it. but they put these trannys behind the 6.4ls. my brothers buddy has a 6.4l, with a spartan tuner. and NOS. with a bone stock torqshift with a stock convertor. and it holds fine. im still calling bts. but if anyone has any imput on the 4 wheel drive its appreciated
Old Apr 6, 2010 | 04:02 PM
FastCR's Avatar
did he have good luck with the pcs controller? They seem to be hit or miss on the ford trans.
Old Apr 6, 2010 | 06:06 PM
dan33klein's Avatar
yeah it works great behind his 12 valve in the 05 ford. he just wants a stick, so im giving him one. and i want his torqshift. where is the spedo located on a 05 ford f250?
Old Apr 7, 2010 | 12:30 PM
Karls03's Avatar
I've been told the speedo and the ABS are in that wiring harness that goes to the top of the rear axle. I didn't see anything in the transfercase tail housing or the trans. I wouldn't be surprised if I missed it because it doesn't look like anything in my older rigs.
When you find it, let us know.
Old Apr 7, 2010 | 08:39 PM
dan33klein's Avatar
if it reads off the rear axle. how am i gunna hook my dodge spedometer back up
Old Apr 8, 2010 | 06:43 AM
HeavyAssault's Avatar
Transfer case should be able to be used with a simple switch. Just need to power the motor on the t-case. Look at the motor on the case now, how many wires are feeding the motor?
Old Apr 8, 2010 | 07:16 AM
dan33klein's Avatar
i havent checked yet. i heard the switch in the cab goes to a power box in the fender or someplace. and then goes to the transfercase. im gunna have to trace some wires when i do the swap
Old Apr 8, 2010 | 12:29 PM
It may power the vacuum pump to actuate the hubs. The T-case should be able to be switched separate from that pump.
