wheel and tire help asap please
Old Apr 5, 2010 | 10:16 PM
bobracing32's Avatar
Default wheel and tire help asap please
Ive got a 5 inch lift and want a 3 inch body whats the tallest tire i can run, thanks guys
Old Apr 6, 2010 | 06:48 AM
DIESELDENT's Avatar
I personally dont like 3" or bigger body lifts, there was a pic of a truck on here a while back with one that hit something and the cab came off. I am a avid off-roader and I know that any kind of angle or flex puts a lot of stress on thoes body bolts and putting a body lift on would give it more leverage. You should be able to run up to a 36 with just the 5" lift. With the body ive seen up to 40's with minor trimming.
Old Apr 7, 2010 | 10:36 PM
crzycummins's Avatar
well i would think about that body lift...i personally dont care for em but hey its your journey...ive got a 2002 with a 2.5" level kit and im runnin 35's on 16in wheels. so with a bigger lift i would say around 37's depending on the pattern and the back spacing. as for the body lift also i would imagine you could go a bit bigger but like i said it depends on the back spacing as well as the tread pattern bc of tire rub mainly when you crank the wheel hard.
Old Apr 8, 2010 | 03:47 PM
1993firstgennewbie's Avatar
40s all day my brother has a 6in skyjacker and hes got 37.5 semi tires no rubing at all personaly id forget about the 3in body lift and just get the 6in suspention and run 37s the only problem is ur truck will look like everyone elses
Old Apr 8, 2010 | 09:54 PM
LawnScum's Avatar
i have the 4.5 skyjacker and a 2 1/2 inch leveling kit and i fit 37.13.50s on a 12 inch wide rim.
salty4life
Aug 20, 2015 10:46 AM
cutthroatxxx
Jun 22, 2015 10:16 PM
dallasca
28
May 26, 2015 12:58 AM
wyoborn&bred
Nov 25, 2014 06:35 PM
