Will driving with a seized turbine cause any damage?
Old Apr 4, 2010 | 06:13 PM
85_305's Avatar
Being Evaluated
Default Will driving with a seized turbine cause any damage?
My turbine thats right behind the intake piping is seized up (see my other thread). It's SOLID. Doesnt turn or move period. But I need to drive a 12hour round trip next saturday. Will this cause any issues besides the truck smoking a ton? Will it suck more fuel (or less since it isn't boosting)? Will anythign burn up or blow up?
Thanks
Matt
Old Apr 4, 2010 | 06:31 PM
94 12valve's Avatar
I don't think driving is a good idea ... a 12 hour trip is way out of the question.
If you do drive it it will suck WAY more fuel than normal, smoke a ton, and your EGT's will be through the roof.
Old Apr 4, 2010 | 06:36 PM
85_305's Avatar
Being Evaluated
Dammit. Thats def. not what I wanted to hear
Old Apr 4, 2010 | 07:44 PM
wes-cummins's Avatar
i wouldnt drive it any where if i didnt have to? if you have to move the turck i would unhook the the boost line coming out of the turbo, the motor is having a hard time sucking air throgh a seized turbo
Old Apr 4, 2010 | 07:47 PM
85_305's Avatar
Being Evaluated
Ok thanks for the advice man. I'm trying to figure out what the hell to do to fix this
Old Apr 16, 2010 | 12:41 AM
hereismylife's Avatar
think about where the egts were before the turbo went out. Now take the air out of motor. I would not even drive 5 min with a turbo that is seized. If it does start to move you might not have a engine left...either way 12 hour drive you would be out of a engine,turbo,fuel wasted also pulled over for all the smoke.....NOT GOOD
Old Apr 16, 2010 | 01:55 AM
12valvetater's Avatar
When I blew my last charger I could barely make it up the hill to get to my house an 1/8th of a mile away.
Old Apr 16, 2010 | 05:15 AM
DB Admin's Avatar
Banned
pick up someones old stock charger takes 30 mins to change it , most performance shops has a pile of stock turbos , use the price quote forum here to locate one should be less than $350
Old Apr 16, 2010 | 08:16 AM
85_305's Avatar
Being Evaluated
Thanks for the input man good info
The price quote can find me used turbos?
Old May 20, 2010 | 09:11 PM
Uncle Bubba's Avatar
You can use the price quote system to get sponsors attention. We don't suggest it as a habit but in this case it's somewhat of an emergency. You can also put a post in the wanted section to section to get to members.
