raptor 150 install
Old Apr 3, 2010 | 05:01 PM
hulse09's Avatar
Default raptor 150 install
i just recived the raptor 150 for my 00 dodge short box extended cab 5spd. there is not alot of room to mount it on the frame and was wondering if some1 knows of a good place to mount it and pics would be nice
Old Apr 3, 2010 | 07:27 PM
LawnScum's Avatar
inside of the frame. between the fuel tank and crossmember. goodluck
Old Apr 3, 2010 | 08:01 PM
Sawman's Avatar
that is where i mounted mine. Only mod i had to do was i took a floor jack and a piece of medal and pushed floor board up about a half inch to give it room and to get rid of vibrations. Did your raptor come with fittings to run 1/2" line all the way to the vp or just to the filter?
Old Apr 4, 2010 | 08:47 AM
hulse09's Avatar
it came with the fuel line and i think it will go to the vp
Old Apr 4, 2010 | 12:02 PM
The Raptor only goes to the Filter. If you run it straight to the VP then your not filtering the fuel.
Old Apr 4, 2010 | 09:31 PM
Sawman's Avatar
ok why do that not send the supply fittings to go from filter to vp? Can you get the fittings?
Old Apr 4, 2010 | 11:13 PM
We offer the Vulcan Filter to Injection Pump Big Line Kit.
Big Line Kit
Old Apr 6, 2010 | 10:59 PM
Fishin2Deep4U's Avatar
Vulcan has a simple "Big Line Kit".
Basically, adapters and fittings to go from the filter to injection pump. It also has a pressure 90* for the injection pump connection giving you that pressure port access. The hose is Bio/ veg/ diesel compatible and is better line than the blue air line included in the aftermarket fuel system kits.
Dave
450r racer
8
Dec 21, 2015 06:42 PM
lkfldredneck
Jun 25, 2015 04:51 PM
Apr 29, 2015 08:20 AM
Gman30
Dec 27, 2014 12:46 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
