38R on Cummins 12 valve
Old Apr 3, 2010 | 04:51 PM
F450 Spartan's Avatar
Default 38R on Cummins 12 valve
Anyone ever put a 38R on a cummins 12 valve as a single or twins. Would this be a good match.
Thanks
Old Apr 7, 2010 | 08:18 AM
dan33klein's Avatar
garret 38R?
i have not but it would be sweet=]
Old Apr 7, 2010 | 03:33 PM
12valvetater's Avatar
What are the specs on this?
Old Apr 11, 2010 | 06:37 AM
TheseThe GTP38R Turbo
A Garrett exclusive ball bearing cartridge for unbeatable response, efficiency, and durability. Elimination of the thrust bearing eliminates Failures at elevated boost levels
The 88mm GT compressor wheel provides 33% more flow than the stock 80mm wheel. Ported shroud housing improves compressor flow range for surge control
1.00 A/R turbine housing for free flowing exhaust with reduced back pressure and up to 200° F reduction in exhaust gas temperature
Maximum recommended boost level is 40psi
Old Apr 11, 2010 | 09:03 AM
MotorOilMcCall's Avatar
Only 40psi? Why bother?
Plus an 88mm wheel seems awful big, even with a ball bearing setup. I ran an HX55 on my 98 12V for quite a while. Nice turbo, and not overly laggy either. It wasn't ideal for the street, but for 2.8" classes it was ideal.
12 valve 97
21
Jan 27, 2016 04:59 PM
PeteBug
Jun 11, 2015 12:16 PM
river rat
May 18, 2015 05:04 PM
Bigsexyhick
Diesel Engine Conversions
Mar 19, 2015 09:57 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
