Diesel Performance Plus, LLC Visit - Diesel Performance Plus. LLC
3in1 Diesel Combo Gauges
Old Apr 3, 2010 | 12:51 PM
DppPower's Avatar
Default 3in1 Diesel Combo Gauges
I made a post about these back when they first got released but there has been some changes to them and Glow Shift has added another option now.
3 in 1 Combo Gauge - Boost, Exhaust Temp, Temp Readings
GlowShift’s newly released 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from ten backlighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure from 0 to 60 PSI, exhaust temperature from 200 to 2200 degrees Fahrenheit as well as a choice of oil, coolant or transmission temperature from 68 to 302 degrees Fahrenheit. Boost pressure, exhaust and temperature sensors are all included. Select from ten bright backlighting colors as well as two color cycling modes including a color fade and color cycle feature. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Install the included temperature sensor to either your oil, coolant or transmission senders to effortlessly monitor it using the digital temperature readout on the unit itself. Each package also includes a gauge pod to easily mount the unit on your dashboard. Each gauge includes GlowShift’s standard one year limited warranty as well as free technical support.
Gauge Ranges:
Boost 0 to 60 PSI
Temperature 68 to 302 F
Exhaust Temperature 200 to 2200 F
•60mm (2 3/8in) Gauge with Mounting pod
•Monitors 3 vital engine readings in one, easy to use unit
•10 color illumination with color recall technology
•Digital exhaust & temperature readouts
•Includes boost pressure, exhaust and temperature sensors
•1 year limited warranty & free technical support
3 in 1 Combo Gauge - Boost, Exhaust Temp, Pressure Readings
GlowShift’s newly released 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from ten backlighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure from 0 to 60 PSI, exhaust temperature from 200 to 2200 degrees Fahrenheit as well as a choice of oil or fuel pressure from 0 to 150 PSI. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Boost pressure, exhaust temperature and pressure sensors are all included. Select from ten bright backlighting colors as well as two color cycling modes including a color fade and color cycle feature. Install the included pressure sensor to either your fuel system or oil gallery to effortlessly monitor it using the digital pressure readout on the unit itself. Each package also includes a gauge pod to easily mount the unit on your dashboard. Each gauge includes GlowShift’s standard one year limited warranty as well as free technical support.
Gauge Ranges:
Boost 0 to 60 PSI
Pressure 0 to 150 PSI
•60mm (2 3/8 in) Gauge with Mounting pod
•Monitors 3 Vital Engine Readings in One, Easy to Use Unit
•10 Color Illumination with Color Recall Technology
•Digital Exhaust & Pressure Readouts
•Includes Boost Pressure, Exhaust Temperature and Pressure Sensors
•Gauge Dims for Nighttime Driving
•1 Year Limited Warranty & Free Technical Support
I will do a special of $159.00 shipped for either one to the first 25 people to place an order.
If you have any questions please let me know.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 1, 2015 08:10 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
