06 24V is blowing 2amp ignition fuse
Old Apr 2, 2010 | 06:39 PM
97Blackout's Avatar
Default 06 24V is blowing 2amp ignition fuse
I have a 2005 cummins and when I cycle the key on it blows the 2 amp ignition feed switch fuse. Has anyone had this problem if so can you help me out it is giving me a headache.
Thanks
Old Apr 2, 2010 | 09:08 PM
dangerous1965's Avatar
Yeah I had that happen and put a 5 amp in no problems in over a year. When you cycle you mean turn it over if so the starter is starting to draw alot more due to being worn out or maybe damaged/??
david.burger
May 30, 2015 08:25 AM
