question for 1st genners about smoke screw
Old Apr 2, 2010 | 09:19 AM
Randall's Avatar
Default question for 1st genners about smoke screw
has anyone ever put a longer smoke screw in?
Old Apr 2, 2010 | 10:52 AM
hiboy_76's Avatar
i just took my afc spring out, does about the same thing. you have to contol smoke with your foot instead of the afc doing it.
doing this lets you fuel pin drop all the way down = full fuel all the time
Old Apr 2, 2010 | 10:57 AM
coalrollin12v's Avatar
would this cause issues with the factory automatic? overdrive that is
Old Apr 2, 2010 | 01:49 PM
stackx2's Avatar
some people take it out and tack a little extra weld on the end and then sand it down to shape
Old Apr 2, 2010 | 03:11 PM
RSWORDS's Avatar
I think your thinking of the full power screw.
No reason to extend it, All your gonna gain is smoke and no power. Removing the spring can actually hurt bottom end performance. Too much fuel to soon can put out the fire and cause poor performance and slower spool up.
Old Apr 2, 2010 | 04:31 PM
Randall's Avatar
im glad i asked before just doing..hahaha
Old Apr 5, 2010 | 04:01 PM
hiboy_76's Avatar
taking the spring out really does hurt low end performance, my truck diesnt want to spool well after i turned the full fuel screw(it was only a turn but still) If your truck is all stock just take the spring out because my truck ran pretty good on the low end with just the spring out.
Old Apr 5, 2010 | 04:48 PM
RSWORDS's Avatar
You can use teh smoke screw to gain anything you will with no spring and still retain full AFC function.0
Old Apr 5, 2010 | 06:26 PM
JBradley500's Avatar
with my denny t pin i used a 6mm washer between the fuel pin and the metal part of the diaphragm to shim the fuel pin down... i also machined the afc tophat to get more travel upward but you apparently dont want that anyway.
Old Apr 5, 2010 | 07:24 PM
Randall's Avatar
i sanded the little plastic washer to about a 1/16 of an inch, i didnt notice anything tho
mattshow123
14
Mar 12, 2018 01:41 PM
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
Fred427
Jun 29, 2015 09:43 AM
