Getrag
Old Mar 31, 2010 | 10:40 PM
BIGREDGOAT's Avatar
Default Getrag
hey guys im still learning all this getrag stuff, and iv been trying to get my mileage up. it turns out that my tranny is a 4spd with granny, i was wondering if they put od in em. bc im averaging 15mpg empty runnin 30 miles to school and driving in town and then driving back and going to work. on long drives where i get to level it out i get about 17mpg. thats with the cruise. and 2 days ago i counted my differential gears and it turns out that i have 3.54. so anybody have a good but kinda cheap idea? and would 75hp injectors help my mpg at all?
Old Mar 31, 2010 | 10:43 PM
RSWORDS's Avatar
Unless someone swapped in another tranny (unlikely) your getrag is an OD tranny...
The gears are....
1st: 5.531
2nd: 3.017
3rd: 1.60
4th: 1.0
5th: 0.77
Reverse: 5.029
Bump your timing 1/8" and you should pick up a mpg or two.
Old Mar 31, 2010 | 10:44 PM
big bad diesel 416's Avatar
Site Sponsor
so your a 5 speed getrag or an auto?
Old Mar 31, 2010 | 10:54 PM
BIGREDGOAT's Avatar
its a 5 speed. and it only runs like 12 or 15 mph in first, is hat normal?
Old Mar 31, 2010 | 11:08 PM
tltruckparts's Avatar
mine only does like 4 or 5 mph in 1st. 2nd gear will do 12 or 15. if you count first gear as granny and 2nd as 1st, thats normal. but these arent known as a granny transmission, just a 5 speed OD manual
Old Mar 31, 2010 | 11:26 PM
Site Sponsor
crawl under that sucker and look the trany should say GETRAG casted in the case
should look something like this
Old Apr 1, 2010 | 08:01 AM
BIGREDGOAT's Avatar
since it has od then it should be able to get over 80mph. thats my top speed.
Old Apr 1, 2010 | 08:29 AM
Budgreen's Avatar
91.7mph!!
haha I have the same setup. I would suggest a 366 governor spring, it will be a HUGE help on the highway.
does anyone use first? I did once towing when I started on a steep hill but that was the only time.
Old Apr 1, 2010 | 09:38 AM
BIGREDGOAT's Avatar
im trying to find out how to lower my rpm's, is the nv4500 differently geared?
Old Apr 1, 2010 | 03:30 PM
Site Sponsor
it would be easier to change the rear end ratio
