engine runs but no power
Old Mar 31, 2010 | 11:30 AM
cindy's Avatar
Default engine runs but no power
2001 dodge cummins 5.9 liter.. just bought deisel fuel and less than 10 miles lost power
.. went up a hill then down the hill and then lost power.
replaced fuel filter.. gas settlements looks dark. what should I look for first for problem?
Old Mar 31, 2010 | 11:57 AM
AF1CUMMINS's Avatar
check the simple things first. what's your fuel pressure runnin? check the filter again, sometimes you can get trash in the system. check for boost leaks
Old Mar 31, 2010 | 03:29 PM
Budgreen's Avatar
gas?
Old Apr 2, 2010 | 09:53 AM
cindy's Avatar
yes think thats what it was.. truck had been running fine.. then filled up with gas/diesel and within 10 miles started having problems. I cked all the simple things, changed the fuel filter.. nothing looked wrong.. so we drained all the gas out ..it was dirty.. then refilled with diff gas from a diff store and now it runs again until next time. thanks for responding.
Old Apr 2, 2010 | 10:26 AM
RAW's Avatar
RAW
I think the general thought is why is GAS being used? I can only hope that the term "gas" is being used in place for "diesel" or "fuel".
Old Apr 2, 2010 | 11:18 AM
cindy's Avatar
yes the term "gas" is being used loosley meaning fuel.. if you read the first and 2nd posts i said diesel.. " just bought deisel fuel " "filled up with gas/diesel" i know the truck runs on "diesel".. i rcvd post from 1 asking if i added gas.. Im not an idiot that does not know the difference between ethanol gas and diesel fuel or if I added gas/ "FUEL" to the truck.
this problem appears to have been SOLVED ..looks to have been because of dirty diesel fuel added. the store may have been at the bottom of their supply when i FILLED up. I replaced the fuel filter, then drained that fuel/diesel - which had gunk/trash in it. cked all the simple things.. then added diff "diesel" (not the same fuel i drained). It has not had a problem since. hope it was just "bad diesel". will let you know if any other problems come up.
Thank you AF1CUMMINS for responding with a reply that helped.
Old Nov 11, 2016 | 06:47 PM
Jgreim66's Avatar
Default 2002 cummins 5.9 diesel
Have a question my husband has 02 cummins 5.9 it starts and runs but when you give it gas it has no power won't go what could it be
burndiesel
10
Feb 7, 2023 01:15 AM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
