tech 2005
Old Mar 31, 2010 | 10:34 AM
tech 2005's Avatar
Default tech 2005
I have a 2004 Ford F250 and it was blowing white smoke and I took it to the Ford dealer and they want 1,900.00 to fix it and I don't have it !! They said my EGR Cooler is bad with out getting out of there seat. I removed the EGR Vlave and it wasn't very dirty and a little carbon on the inside and some green stuff inside the Boost tube. What would be the cheapest way to fix the problem? Delet Kit or EGR Cooler replacement ?
Old Mar 31, 2010 | 12:31 PM
DIESELDENT's Avatar
Welcome to db
Moved to the power stroke section.
Old Mar 31, 2010 | 01:29 PM
HeavyAssault's Avatar
Do all the work yourself. Replace the EGR cooler or get a delete kit are both good choices.
Old Mar 31, 2010 | 03:28 PM
Mdub707's Avatar
Just get an EGR cooler delete kit. You can get them for $300 now or less, and you can do it yourself. It is not a hard job at all, but it is somewhat time consuming. Plan at least a full day for your first time. An extra set of hands will come in handy too.
Old Apr 1, 2010 | 05:50 PM
mlinder's Avatar
i just put in a sinister full delete kit < got off ebay 275 shipped.
Old May 25, 2010 | 07:56 AM
tech 2005's Avatar
Default What to do about EGR problem?
I have a 2004 4x4 6.0 power stroke and need to put the DELETE KIT on will it hurt if its a daily driver? I know it says for off road use only but there is nobody to check to see if I have the delete kit on it. I need to do this myself and this looks like the best way to go can anybody help me?
Old May 25, 2010 | 08:34 AM
Mdub707's Avatar
It will help, not hurt. Every 6.0 should have this done IMO. I've heard you can get the Sinister or the RCD one's on ebay with the "make an offer" for around $250. Have at it!
Old May 25, 2010 | 10:17 AM
lubbockguy1979's Avatar
U likely have a bad oil cooler so while ur there fix the problem. It is more than likely what caused the egr cooler to fail. I would consider getting a coolant filter to help with longivity of the oil cooler. Its costly but headgaskets and studs will definately give you piece of mind and is not to much further in there.
Old May 25, 2010 | 11:37 AM
Mdub707's Avatar
Yes, do an oil cooler rebuild while you're in there.
May 7, 2015 02:50 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
