twins enough?
Old Mar 30, 2010 | 11:24 PM
notsosimple's Avatar
Default twins enough?
i have a 13mm industrial injection pump. 105 ml injectors. and i just bought a twin set from hightech turbo. 67x71 w/13mm housing. and a 80mm to go with it.. will i overspin or gernade my twins. do i need to go bigger?????
Old Mar 30, 2010 | 11:30 PM
94 12valve's Avatar
how many cc's of fuel does that 13mm pump push?
What are you planning on doing with this truck, drag race?
what housing is on the primary charger and does it have a wastegate?
Old Mar 31, 2010 | 12:32 AM
moneyman_09's Avatar
I would think you would blow a head gasket or your innercooler b4 you blow up ur turbos just watch you egts and boost pressure
Old Mar 31, 2010 | 11:22 AM
94 12valve's Avatar
Im gonna assume thats a s480 as your primary, set the gate right on the secondary and your turbos will be fine
12 valve 97
21
Jan 27, 2016 04:59 PM
