timing wont stay
Old Mar 30, 2010 | 09:32 PM
the tuggster's Avatar
Default timing wont stay
just put a new p7100 pump on my 97 12v the timing gear keeps sliping on the pump shaft after it runs for 15min or so
Old Mar 30, 2010 | 09:36 PM
FastCR's Avatar
make sure your torquing to spec and clean the shaft off with electrical parts cleaner. as well as the inside of the gear, any grease/oil will make it slip.
Old Mar 30, 2010 | 09:37 PM
Benjamin's Avatar
Bombardier
clean the shaft and the tapered part of the gear the shaft seats in with brake parts cleaner, make sure there is NO residue left on there, do not wipe the shaft off with a rag as any fuzz or fibers will make the shaft not seat correctly.
also torque the nut down to 122 ftlbs. i always do 135 after just to make sure.
Old Mar 30, 2010 | 09:40 PM
BIG NIG's Avatar
i do 90ish lbs then another 90*
NEVER had one slip or have any problems
Old Mar 30, 2010 | 11:33 PM
94 12valve's Avatar
the torque spec for that nut is 144ft/lbs, I go to 155 ft/lbs just to be sure.
here is another vote for electrical contact cleaner it cleans great and leaves nothing behind
Old Mar 30, 2010 | 11:44 PM
Benjamin's Avatar
Bombardier
thanks for the clarification, i found that spec on a p-7100 install PDF i had.
Old Mar 30, 2010 | 11:51 PM
That sounds about right, iirc
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
