new steering box problems
Old Mar 31, 2010 | 05:26 PM
94dizzyram's Avatar
Default new steering box problems
Got my new steering box on and it had a ton of slack in it. So I adjusted it out. It also takes twice the effort to turn right as it does to turn left. ANybody got any ideas.
I loosened the bolt a little bit. I had it to tight. That helped a little bit. It still just doesnt feel right though. Any help would be greatly appreciated. To me I dont feel that I should have even had to adjust it at all.
Last edited by 94dizzyram; Mar 31, 2010 at 05:26 PM. Reason: Automerged Doublepost
Old Mar 31, 2010 | 08:11 PM
01trailerpuller's Avatar
You might have to back it off some more is all I can think of.
Old Mar 31, 2010 | 08:39 PM
94dizzyram's Avatar
I am going to try that tommorow after work. Got any idea of how to set the wheel back to 12. its about a 1/4 turn off
Old Mar 31, 2010 | 08:43 PM
That is easy. There is an adjustment point to the left of the steering box if you are looking at it form the front. Have someone sit in the cab loosen the two bolt the twist it forward or backwards. it will start to turn your steering wheel. Have the person in the cab tell you when it it strait.
Make sure the steering wheel is unlocked before you start.
Old Apr 1, 2010 | 03:26 PM
94dizzyram's Avatar
Thanks I will try that for sure. The rep from A1 cardone(the company who rebuilds the boxes) said for me to disconnect the pitman arm and the steering linkage and turn the shaft with a pair of vise grips with the truck running. I think he is trying to make sure it is not something else in the front end. The truck didnt do that before so I guess I am going to just get another box. Thanks for the help 01 trailerpuller.
Old Apr 3, 2010 | 02:46 PM
94dizzyram's Avatar
I got another box coming tommorow. I am going to keep my fingers crossed.
Got the new box and it is all. Now gotta get a brace to keep it that way.
Antwhite19
Aug 23, 2015 06:07 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
GCTownes
Oct 21, 2014 10:17 PM
sweetv8s10
Oct 7, 2014 09:47 PM
