headgasket and arp head studs
Old Mar 30, 2010 | 12:34 PM
hop sing's Avatar
Default headgasket and arp head studs
I blew a head gasket i have a replacement marine gasket,and arp studs just looking for the correct way to do the job right any knowledge and help would be appreciated thx for your time! Hop Sing
Old Mar 30, 2010 | 12:37 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
make sure you deck the head while you got it off. follow arps rec. heat cycles and tq
Old Mar 30, 2010 | 01:15 PM
94 12valve's Avatar
arp's directions call for no heat cycles, all the retorques are done cold
Old Mar 30, 2010 | 01:26 PM
diesel pap's Avatar
well thats what i mean
Old Mar 30, 2010 | 01:28 PM
BIG NIG's Avatar
torque them to 135lbs, and wile you have the head off bottom tap block. dont machine the rockers just grind out the valve covers a little.......its faster and alot cheaper. did you get the .020 over marine gasket?
get the new gasket in, get it to operating temp
do a retorque
get it back to temp, do a retorque
let it cool down to the block is luke warm, and do a retorque
most likely you will need to readjust the valves
drive it for a day or so, not much boost
do another retorque
drive it and get all of it, dent the floor board with the pedel
retorque and check valve adj
Old Mar 30, 2010 | 01:34 PM
diesel pap's Avatar
a cummins .020 marine
Old Mar 30, 2010 | 01:35 PM
12valvetater's Avatar
Machine the pedestals. Anything worth doing is worth doing right.
Old Mar 30, 2010 | 01:43 PM
BIG NIG's Avatar
.020 gaskets are great for lower compression, haze at idle, improper fuel atomazation, hard starts, melting/cracking pistons do to improper injector protrusion into the piston bowl
you can spend the money machining the pedestals, but what about the years they were selling studs and didnt recomend machineing them? you can just leave the washer off the pedestals and if you bottom tap the block you dont have to do anything
Old Mar 30, 2010 | 02:28 PM
94 12valve's Avatar
thats why you run thinner injector washers with the thicker gasket.
I bottom tapped my holes and used the washers like your suposed to and have had no problems. also it took me 20 min to mod all 5 of my rocker pedestals, to me its worth doing right
Old Mar 30, 2010 | 04:30 PM
All 5 eh?
