600 HP LB7 Duramax
Old Mar 30, 2010 | 01:14 AM
BW Motosports's Avatar
Exclamation 600 HP LB7 Duramax
Well my original plan was to build a 1000hp pullin truck but do to lack of cash i have desided to by a used LB7 and do some work to it. Im not usin my 01 cuz its my trailor pullin rig. Im tryin to get 600hp give or take. Just wanted to get ideas for parts to use. Im planing on useing a Aurora 5000 turbo to flow the air but still lookin for ideas for the rest of the truck. The one thing i am having trouble finding is a cam. Any ideas and tips are a big help. And if there is anyone who hase a duramax making this kinda power i need to find a good transmission so i assume anyone with a 600hp duramax would know what to use.
sorry about the bad spelling.
Old Mar 30, 2010 | 01:18 AM
2500HeavyDuty's Avatar
is tuck going to be a pulling truck cause that a5k is a 2.8 turbo and whole lot more than 600 will be needed to even competitive in the class
Old Mar 30, 2010 | 01:24 AM
No its goin to be my daily driver, but ill brobly do some pulling at county fairs and such and a little dragging at the local track.
Old Mar 30, 2010 | 01:34 AM
alright. about the cams, afaik most cams require different valve springs. Socal diesel, compcams.
all that really aint required for that kind of power. even a smaller upgraded turbo can make that kind of power, and be alot more streetable
Old Mar 30, 2010 | 02:23 AM
alright thanks, im planning on workin with upstate diesel in new york. ill see were it goes.
what do you think about the BD power super max turbo insted of the a5k
Last edited by BW Motosports; Mar 30, 2010 at 02:23 AM. Reason: Automerged Doublepost
Old Mar 30, 2010 | 07:36 AM
Tyler@MPF's Avatar
600 is not hard to achieve with your truck. I suggest EFI Live tuning, built transmission, lift pump and a BD Supermax turbo kit. This set-up has been proven at 650 numerous times. If you have any questions give me a shout.
You can achieve 520-550 on a stock turbo with max effort tuning.
Old Mar 30, 2010 | 12:22 PM
I hear alot of mixed reviews about the BD turbo, the HTT turbo i hear nothing but good things about them.
but yeah, built transmission, turbo and lift pump would work well, depending out how well the truck is maintained it might need a new cp3
Old Mar 30, 2010 | 01:48 PM
I was planning on doing dual cp3 pumps. proply the ats kit. And do yall think headstuds are needed for running upwards of 40 psi. And my other consern is injectors anyone with the LB7 knows of the injector failiors.
Old Mar 30, 2010 | 01:58 PM
Tyler@MPF's Avatar
You won't need to waste the money on dual cp3's unless you plan on building your engine. We have had great luck with the BD Supermax turbos we have sold.
If you want to do a CP3 upgrade get a LMM pump. It is a upgrade for the Lb7, but will require EFI Live to get it tuned correctly. Studs won't be needed at 40 psi, we have guys running 50-60 on stock head bolts.
Old Mar 30, 2010 | 02:04 PM
thanks for the info. i might do dual cp3's cuz eventully id like to really build the engine. do yall think i would need to upgrade my injectors.
