Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
hard miss what run no power
Old Mar 29, 2010 | 09:23 AM
kdxkent's Avatar
Default hard miss will not run no power
This problem is on a good friend of mine's truck. All stock. This is what it does: it will start missing and banging hard and no power. He has been able to cycle the key once and then the fuel gauge will not work and the check engine light is on. He then cycles the key again and the fuel gauge works and the check engine light goes off. Truck runs fine.
Took to dealer and they said the code always shows a problem with injector 7 of 8. Is this really a problem with the injector or is it a electrical issue somewhere? truck has 155000miles
Old Mar 29, 2010 | 09:09 PM
3928dustin's Avatar
the lly's have an issue with the injector harness on injector no.2 and 7
Old Mar 29, 2010 | 10:48 PM
2500HeavyDuty's Avatar
it could be something as simple as he wire harness for the #7 injector (passenger side all the way back)
Old Mar 30, 2010 | 05:39 AM
kdxkent's Avatar
Okay, now is there one big harness to all the injectors or are you talking about a short harness just to the injector?
Old Mar 30, 2010 | 06:46 AM
jlawles2's Avatar
I would check both. The big wiring harness next to the alternator. If it is not rubbed through, put a piece of heater hose on it. (insurance) And then the ice pick fix to the #7.
GM made the wiring harness to the #2 and #7 injectors short. That is one of the reasons that they have issues. Over time, the short harness causes it to loose connection at the injector plug.
Old Mar 31, 2010 | 08:18 AM
Rttoys's Avatar
Do this, it'll probably fix it:
Diesel Place
Old Apr 4, 2010 | 10:07 PM
kdxkent's Avatar
Okay guys thanks we will try it and update when we get it done.
Timglow546
8
Jun 3, 2015 10:13 PM
southeren_born
Mar 28, 2015 09:19 AM
