is this too hot?
Old Mar 28, 2010 | 08:30 PM
redwood logger's Avatar
Default is this too hot?
this is when i am pulling hills loaded or empty. it seems like it is running hotter now with the new water pump.
Old Mar 28, 2010 | 08:36 PM
moneyman_09's Avatar
I have seen mine there a couple times but it never stays that hot.
Old Mar 28, 2010 | 09:02 PM
DieselPerformanceGuy's Avatar
try a new t-stat that made mine run way cooler. The old t-stat must have stayed shut all the time, because it would get that hot during the summer sometimes, and the fan would never come on. Now my fan is on almost all the time, which kinda sucked this summer
ArizonaRedneck's Avatar
no mine runs that hot to and its the same year kinda makes you wonder but not a lick of problems yet with the cooling system
Old Mar 28, 2010 | 09:08 PM
jasonfriedlin's Avatar
That can;t be good for it. Im curious as to how hot that really is but normally anything over the halfway mark on any stock gauge on any car can't be good.
Old Mar 28, 2010 | 09:10 PM
i would bet you could put a regular gauge in it and it wouldnt be as hot as you think and is your fan kicking in
Old Mar 28, 2010 | 09:18 PM
Budgreen's Avatar
2 words.
intercooler soak
mine ran about the same.. for 3k miles worth of towing. no ill effects
Old Mar 28, 2010 | 09:55 PM
RSWORDS's Avatar
Originally Posted by Budgreen
2 words.
intercooler soak
yep, That and check your ground from the battery negative to the core support. A bad ground will cause those gauges to read backwards for some reason.
Old Mar 28, 2010 | 10:09 PM
I CANT TELL IF THE FAN IS KICKING IN OR NOT, IT ONLY GETS THIS HOT ON HILLS THEN GOES BACK DOWN TO THE HALF WAY POINT ON THE GAUGE AFTER I GET ON FLAT GROUND AGAIN
Old Mar 28, 2010 | 10:19 PM
seandonato73's Avatar
try a new thermostat mine never goes mush past the after the cold line
