Diesel Auto Power Visit - Diesel Auto Power
Tunnel Ram Intake Manifold
Old Mar 28, 2010 | 01:56 PM
jkidd's Avatar
Default Tunnel Ram Intake Manifold
This product greatly improves the airflow on your 5.9L cummins. Basically there is a bottleneck in the intake system. The air comes out of the intake manifold horn and then has to do a 90 degree turn to reach the cylinders. Cylinders 1,5&6 run hotter on our trucks because they are further away from the intake of air. Among other mods, pulling trucks use $1600 custom intakes with individual runners to get rid of this problem.
You can take your head off and port the intake. This is expensive and takes a lot of time. The gains you will see with this Tunnel Ram Intake Plate will be equal to a mildly ported head.
1. Boost (a restriction) will decrease slightly
2. Spool up will be about 100rpm sooner.
3. Less unburnt fuel= more efficient.
4. Temperatures in Cylinders 1, 5 & 6 will decrease about 100 degrees, lowering overall temps by 50degrees.
It is made out of Aluminum and is compatible with stock or aftermarket air intake manifolds. If you are able to increase flow to cylinders 1, 5 & 6 by 10% you will gain HP if you are over-fueled (as many of us tend to be.) Notice the "step" that further restricts airflow in the last picture for 2nd gen.
Pricing until April 1st is $210 for 98-02 + metal gasket for $20. Starting April 2nd it will be $230 + gasket. (stock gasket on 2nd gen intake is paper and is not re-usable)
You can paypal to DieselAutoPower@gmail.com
Pricing until April 1st is $255 for 03-07 + metal gasket (your may be re-usable) for $20 Starting April 2nd it will be $275 + gasket.
Old Mar 28, 2010 | 03:12 PM
Diesel Addict's Avatar
when do you think you would have one made up for the 12v I'm interested in one
Old Mar 28, 2010 | 03:36 PM
zach_west's Avatar
yup need one for a 12v
Old Mar 29, 2010 | 11:20 AM
jkidd's Avatar
It will be a few months. Its in development. Hope to have it Early Summer.
Old Mar 30, 2010 | 12:16 PM
wes-cummins's Avatar
when you get pics and pricing for 12valves pm me im interested in one, grid heater still hook up?
Old Mar 31, 2010 | 10:06 AM
jkidd's Avatar
the intake on the tunnel Ram intake is slightly tilted allowing for you to keep the heater grid and run an aftermarket intake horn.
Old Apr 17, 2010 | 12:18 AM
jkidd's Avatar
Anyone else running one of these?
Old Apr 17, 2010 | 12:30 AM
12vcummins96's Avatar
12v want to know
Old Apr 17, 2010 | 12:35 AM
jkidd's Avatar
date is expected to be mid summer
Old Apr 17, 2010 | 11:15 AM
zach_west's Avatar
just pm me when it's ready
