My 1st mod
Old Mar 26, 2010 | 11:17 PM
martymc81's Avatar
Default My 1st mod
Today I got all the throttle out of my ve pump. Well all I could get easily. I backed the high idle screw out 8 turns witch put the linkage almost touching the fuel line. And I moved the throttle linkage to the inner hole. And I used a nut for a spacer to take up the slack in the cable. Got the idea from RSWORDS. Thanks man. I'm impressed. I still don't have gauges but didn't think this would hurt. It raised the rpm's quite a bit but not sure how much (no gauges). Does anybody think this will effect egt's? And is it possible to over rev the motor now? Also I was wandering what the differance is between this and the 366spring?
Old Mar 28, 2010 | 08:33 AM
pewder's Avatar
There is a governor spring late regulates the rpm threw the pump via the governor spring. That what the 366 spring is, alows the motor to achieve higher rpm's by changing that spring. Only way the motor will go over that is if a runaway accures.
366 spring and a fuel pin are the best mods to start with and are fairly inexpensive.
About 120for a pin and 20 for a spring.
Old Mar 29, 2010 | 09:14 PM
1993firstgennewbie's Avatar
What kind of power can u expect after doing these tweeks such as fuell pin 366 spring star wheel and smoke screw I hear everybody talk about it and I will soon do it to my 93 but nobody has the numbers
Old Mar 29, 2010 | 09:37 PM
ArizonaRedneck's Avatar
gauges 1st in my opinion. i deleted afc,ground my fuel pin, star wheel bottomed out, full fuel screw in advanced timing and i bury the needle on my 1500 degree temp gauge with 28 pds of boost all in about 5 to 10 seconds if you dont have gauges you dont know where your at
Old Mar 29, 2010 | 10:57 PM
big bad diesel 416's Avatar
Site Sponsor
agreed **** melts at 1300* man be careful
Old Mar 30, 2010 | 12:14 PM
martymc81's Avatar
Will backing the high idle screw out 8turns raise EGT'S?
Old Mar 30, 2010 | 12:53 PM
RSWORDS's Avatar
no, what you have done will have very little effect on your EGT's. You dont need to start worring about them until you start messing with teh full power screw.
coal_life
Aug 26, 2015 07:50 PM
tractorcrazy
Apr 10, 2015 04:27 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
93 gulfstream
Oct 5, 2014 09:46 PM
