wh1c hybrid?
Old Mar 26, 2010 | 07:34 PM
monster12valve's Avatar
Default wh1c hybrid?
how many psi do you think is safe to push on a wh1c with a hx40 hybrid kit?
Old Mar 26, 2010 | 08:08 PM
NadirPoint's Avatar
You mean the 60mm compressor upgrade?
I think they max out around 35psi.
They'll do more with enough fuel to push it, but it's just hot air after that.
Old Mar 26, 2010 | 08:33 PM
bowtech's Avatar
A STOCK TURBO IS GOOD TO 35PSI WOULDNT THAT HYBRID IMPROVE THE FLOW AND BE BETTER PAST 35 PSI? IF NOT THEN WHATS THE POINT OF IT?
Old Mar 26, 2010 | 08:43 PM
NadirPoint's Avatar
A bigger impeller will flow more air, but doesn't change the efficiency rate or MAP range of the compressor itself.
Old Mar 27, 2010 | 04:01 PM
has anybody done it? is it worth it? a buddy of mine is gving it to me.. i am saving for a 64/71/14... but is this worth the time and effort to put in? if so is it a decent diffrence?
Old Mar 27, 2010 | 07:33 PM
NadirPoint's Avatar
It depends on fueling. It will give you a little headroom to turn up the pump, but they will not support bigger injectors.
They are a nice cheap upgrade for a basically stock truck, but save your money if you are looking for alot more power in terms of bigger injectors and associated mods.
mike71800b
Aug 18, 2015 03:50 PM
Mar 19, 2015 07:10 PM
Dec 6, 2014 11:00 AM
Dec 1, 2014 08:10 AM
