EGR Delete Lost Power
Old Mar 24, 2010 | 11:19 PM
brad2003's Avatar
Default EGR Delete Lost Power
ok my truck was putting out 23psi boot before the delete now it berly hits 20 and has bad lag time any sugestions would be gratly appreciated. and just woundering if you can get the after maket head studs and gaskets as a kit. thanks for your time
Old Mar 25, 2010 | 08:24 AM
MUDSTROKIN''s Avatar
did you do a full delete or just delete the valve or what? more details please?
Old Mar 25, 2010 | 08:56 AM
brad2003's Avatar
well i no i got red off the tube. that gose to the exhaust. now its just a small one inch tube that circulates the coolant ther.
sinister
sd-egrd02 is the part number i got it off ebay
Old Mar 25, 2010 | 09:24 AM
wow... i'm confused.did you put a block off plate over the valve, remove the cooler and put in a solid up pipe?
Old Mar 25, 2010 | 10:10 AM
brad2003's Avatar
i did a blockoff plate,and removed the cooler but i dont remember a solid tube ther was a one in or 3/4 tube
6.0 Ford Powerstroke EGR Cooler Bypass/Delete Kit : eBay Motors (item 250560089086 end time Apr-07-10 17:54:00 PDT)
that is the kit i bought sorry its alot
Old Mar 25, 2010 | 10:46 AM
mlinder's Avatar
Did it include a block off for the up pipe? here is the one i got to put on mine.
6.0L Diesel 6.0 Ford Powerstroke EGR Valve Delete Kit : eBay Motors (item 310184354542 end time Apr-23-10 19:07:16 PDT)
Old Mar 25, 2010 | 01:17 PM
Mdub707's Avatar
Obviously he capped the up-pipe otherwise he wouldn't be making the 20psi... My guess is you have a leak somewhere, probably on the turbo connections to the exhaust piping.
Old Mar 25, 2010 | 01:41 PM
brad2003's Avatar
ok I checked for a leak it lookes like ther is one but i cant tell wher it is coming from the hole back off the engian compartment is black
Old Mar 25, 2010 | 03:09 PM
Mdub707's Avatar
Well it's exhaust if it's black. Either the downpipe or the up-pipe. Try taking the clamps off and reseating them. I had a heck of a time on an 04 truck before when I did the egr delete to get everything seated properly again. If you have a really tough time you might have to unbolt the up-pipe down on the manifolds from under the truck, then tighten the turbo to the up-pipe, then go back and retighten the up-pipe to the manifold.
Old Mar 25, 2010 | 09:40 PM
brad2003's Avatar
Ok thanks for your help ill try it first thing in the am
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
4estlee
Oct 7, 2014 07:47 PM
