ABS - BRAKE LIGHT
Old Mar 24, 2010 | 08:54 PM
redwood logger's Avatar
Default ABS - BRAKE LIGHT
my abs light on the dash and the brake light are coming on when i use the brakes in reverse. and it feals like the power booster is not working but only in reverse. the only thing i can see wrong on the truck is a rear axle seal contaminating the brakes on one side. would that cause these symptoms or is something else going on?
Old Mar 25, 2010 | 11:02 PM
kieron_kohlmann's Avatar
the brake light comes on with the ABS light that part is normal. it is probably a wacky sensor in the rear. remember that braking in reverse is totally different than braking forwards. in reverse you are also self adjusting the shoes. it probably wouldnt hurt to pull the drums and peak inside. make sure everything moves freely and is lubed up.
good luck!
Old Mar 26, 2010 | 01:52 AM
big bad diesel 416's Avatar
Site Sponsor
open the glove box
remove the glove box
unplug the little box on the fire wall
no more issues
Old Mar 26, 2010 | 09:39 AM
Originally Posted by big bad diesel 416
open the glove box
no more issues
WHAT WOULD I BE UNPLUGGING AND WHY DO I NOT NEED IT ANTMORE?
Old Mar 26, 2010 | 04:25 PM
921stgen's Avatar
The black ABS brain box. Truck will stop better without it. Then after that you can go and disconnect the brake lines on the ABS unit in the drivers side rear frame rail and couple them back together with fittings from napa. Also rebleed your brakes.
Old Mar 26, 2010 | 05:00 PM
Site Sponsor
yup 1st gen ABS SUCKS
Old Mar 26, 2010 | 11:03 PM
seandonato73's Avatar
ha ha i juatg took the bulbs out of my dash
Radioking1777
Jun 9, 2015 04:13 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
ValleyF250
Nov 1, 2014 07:56 PM
