afc tuning for no plate
Old Mar 24, 2010 | 11:29 AM
navalseabee's Avatar
Default afc tuning for no plate
Me and a buddy recently pulled our fuel plates in an attempt to get closer to full rack travel (mack plug is on its way) but both of us are quite happy with the result. we both show around same egt's but less boost more smoke off idle. Im jusy curious if there is a certain way to tune the afc or pump to be ran with no plate.
Old Mar 24, 2010 | 12:38 PM
PhilipR's Avatar
Just make sure it's moving all the way forward to allow full rack..other than that you can adjust the tension on how fast it moves and gives you fuel in the curve.
Old Mar 24, 2010 | 01:07 PM
94 12valve's Avatar
here is how mine is set up with no plate.
The gov arm is adjusted all the way up, afc housing all the way back ( slid to the cab), ground the barrel .090, pre boost screw is backed all the way out, washer flip and swaped the thick washer for another flat one, and the spring is set to fully fuel at 30 psi of boost.
works very well for me I have a slight haze mainly due to the full cuts while driving. At full boost I am grossly overfueled
Nov 30, 2014 02:10 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
hardeercy
Nov 6, 2014 08:08 PM
