Injector Pump Rebuild
Old Mar 23, 2010 | 10:24 PM
Randall's Avatar
Default Injector Pump Rebuild
after installing the denny t stage 2 fuel pin the injector pump started to leak.... it wasn't bad but with 190,000 miles its time to rebuild entire pump... its costing me 900. High? low? average?
Old Mar 23, 2010 | 10:35 PM
tltruckparts's Avatar
industrial injection does a stock rebuild for 750. make sure before you get it rebuilt that it isnt just a gasket thats bad. no need to spend 800 bucks on something when the only thing wrong is a 2 dollar gasket. ive also head that the denny t pin will soemtimes cause it to leak because it dumps too much low end fuel
Old Mar 23, 2010 | 10:45 PM
Randall's Avatar
yeah... i figure if the rebuild still leaks i might go will a P pump.. but idk. I've called around to many places an got the same answer for the cause of the leak. since its got that many miles and being stock, that it started leaking cause changing the pin disturbed stuff in the pump
Old Mar 23, 2010 | 11:17 PM
well if you go pay multiple hundred dollars for a rebuild, it BETTER not leak!
Old Mar 24, 2010 | 10:13 PM
Randall's Avatar
yeah really id kill someone
Old Mar 24, 2010 | 10:59 PM
dieseldawg's Avatar
man stop!!!
where is it leaking from??
Old Mar 25, 2010 | 07:11 AM
hdsidehack's Avatar
check the vent tube on the rear of the pump
there is an o-ring for the pin that rides on the fuel pin
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
Hmfman91
8
Jul 3, 2015 05:52 PM
davidthomas
Mar 24, 2015 12:41 AM
twm011
Feb 24, 2015 09:11 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
