Oil pressure switch
Old Mar 22, 2010 | 09:35 PM
jake 94's Avatar
Default Oil pressure switch
im in need of a new oil pressure switch for my bd pump. its the carter pump i no its crappy and i should upgrade but dont have the money rite now so can you guys lead me in the direction of a new oil pressure switch i believe this is the problem for it droppin fuel pressure. its the switch that goes into the side of the block. Is it bad to just bypass this and run straight power to the LP instead of off oil pressure?
Old Mar 24, 2010 | 09:53 PM
dodge rodder's Avatar
my oil presser switch that send signal to the dash gage went out and instead of gettin a new one i got a mechanical oil presser gage from Autometer. as long as the wiring harness is plugged in it should it should work. just hang it with zip ties and left it connected to the wiring. with whats in your sig you may be pulling the presser down on your pump just a gess tho
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
