BD-Power Visit - BD-Power
BD Power X-Power Chip - 180HP With Gauges
Old Sep 5, 2007 | 03:55 PM
BDPowerDave's Avatar
Default BD Power X-Power Chip - 180HP With Gauges
BD-Power Diesel Performance
X-Power with X-Monitor
Prices Starting at
$400.00 - 180HP
To show our appreciation to the members and staff of the Diesel Bombers, BD-Power Diesel Performance is offering a special forum price on all Dodge X-Power, X-Power Plus and X-Power - X-Monitors combination kits. This limited time offer is exclusive to members of the Diesel Bombers only. If you are not registered and would like to participate in this special offer, simply register and participate in the forums to qualify for the discount.
The BD X-Power Plus will boost horsepower and torque by controlling Injection Duration and Timing. The X-Power Plus is great for those of you who want all the power with out the hassle of having to stack a tuner with a performance chip. The X-Power Plus can be stacked with most tuners but may cause issues associated with too much timing. This is common when stacking tuners with a performance chip that already have high levels of advanced timing. The X-Power Plus uses a dial to fine tune HP anywhere from 0-170 RWHP for optimal power and controllable EGT’s.
The BD X-Power will boost horsepower and torque by controlling Injection Duration only. This works great for those of you who are already using a tuner with high levels of advanced timing and are looking for more power through stacking. This eliminates the issues associated with running to much timing. The X-Tuner uses a dial to fine tune HP anywhere from 0-130 RWHP for optimal power and controllable EGT’s
The BD X-Monitor is our digital gauge package that can be mounted on the Pillar or dashboard. It is available in two or three gauge readouts, and will display EGT’s, boost with an optional third readout for transmission temperature, oil temperature, back pressure or fuel pressure. The X-Monitor will record maximum values and has an alarm mode that can be set for all three display to indicate when you are approaching a pre set temperature or pressure.
Prices Starting at
$400.00 - 180HP
Old Sep 5, 2007 | 04:20 PM
Johnny Cetane's Avatar
COOL! thanks, dave.
Old Sep 5, 2007 | 07:06 PM
Uncle Bubba's Avatar
Hey Dave, great to see a manufacturer gettin so active on the boards, we need the info and with you on here we know were gettin accurate info right from the source.
How about some more info on these boxes. I am ashamed to say that I know nothin about them at this point and really haven't heard any mention of them on the other sites through the years. How do they make the HP, do they tap the fuel pump wire, maybe a set of install directions. This would help get an idea of what were lookin at here and may save me a lot of money down the road. Are the HP ratings listed made with stock injectors or do you need a larger set to make the power.
Again, it's great to have you here as the answer man and thanks for the special deals to.
Old Sep 6, 2007 | 09:21 AM
Good Stuff !!
Old Sep 6, 2007 | 10:33 AM
Thanks, I like it here...
No reason to be ashamed, I know they are shadowed by the bigger name brand chip manufactures and are not in most peoples signature plus we do not advetise as agressively as we should but for the price I beleive they are an awesome alternative to the big brands.
The X-Power plugs into the factory injector lines, 6 connections + Map Sensor, they modify injection duration and timing with a no timing option as well. I will attatch as set of instructions for ya.
May 10, 2015 10:57 PM
mountainmover
Mar 1, 2015 02:47 PM
