Coolant temp goes from like 150* to 190-200*, then goes all the way back down...
Old Mar 21, 2010 | 05:29 PM
85_305's Avatar
Being Evaluated
Default Coolant temp goes from like 150* to 190-200*, then goes all the way back down...
goes all the way back down to 140-150*. This is almost systemic. Is it normal?
Old Mar 21, 2010 | 05:32 PM
bowtech's Avatar
thermostat bad?
Old Mar 21, 2010 | 05:34 PM
85_305's Avatar
Being Evaluated
So it isn't normal for it to cycle like that?
Old Mar 21, 2010 | 06:14 PM
TXHC's Avatar
Competely normal. But if it bothers you , you can replace the Thermostat for another one.
My last 3 12-Valves all did the same thing.
From dodgeram.org...
"Wide fluctuations of the temperature gauge
the result of a large radiator, it is relatively harmless and normal
Cummins has released a revised T-stat that does fix the "problem". The revised T-stat Cummins part number is 3934373. (The old T-stat Cummins Part number is 3928499. ) "
Old Mar 21, 2010 | 06:36 PM
bowtech's Avatar
i never heard of that good to know
Old Mar 21, 2010 | 06:40 PM
85_305's Avatar
Being Evaluated
I figured it was normal, but at the same time I got thinking.. diesels dont like to be ran terribly cool. I wonder if it running so cool could have something to do with my dismal mileage?
I might pick up that new t stat though since cummins decided it's revised and must be better
Old Mar 21, 2010 | 06:46 PM
TXHC's Avatar
I wouldn't worry about it until you're ready for a coolant change. It's a common sight on these trucks to watch the gauge move up & down, but it's not a "problem" or really even a concern and it won't affect how your truck runs. I've heard of people putting in the revised Thermostat and the gauge still moves back & forth. Mine have all been stock and I've never seen any of them reach over 190*, even in 100*+ Texas summer heat.
Old Mar 21, 2010 | 06:52 PM
85_305's Avatar
Being Evaluated
I dont doubt the temp will ever go higher than what it does now, since these trucks have amazing cooling systems. But I wonder how that swaying affects mileage? Running a diesel too cool will hurt mileage so I'm curious to know if it impacts it.
Old Mar 21, 2010 | 09:21 PM
440ctd's Avatar
mine does the fluctuations sometimes and other times it doesnt I know its the thermostat opening and closing but I guess its normal
Old Mar 21, 2010 | 09:38 PM
wes-cummins's Avatar
mine does it althe time when im going 70 + down the highway, its just the tstat opening and exchanging hot coolent for cooler coolent in the enging, nothing to serious, a new tstat might help if your worried
