A-1 stud install
Old Mar 20, 2010 | 06:05 PM
freak007's Avatar
Default A-1 stud install
I just bought a set of A-1 studs... What kind of tap do I need to install them?
Old Mar 20, 2010 | 07:18 PM
tltruckparts's Avatar
it says it right on there website. they sell them for like 20 bucks i think. i dont remember the size but its right on there site i remember that
Old Mar 20, 2010 | 10:06 PM
freak007's Avatar
I know they sell it on their web site... But I am hoping to find one locally... The web site says a 12 x 1.75, but I was wondering specifically if a standard tap would work or if I needed a longer one...
Old Mar 20, 2010 | 10:57 PM
you probably need a longer one if your going to bottom tap the block
Old Mar 20, 2010 | 11:07 PM
freak007's Avatar
anyone know for sure?
Old Mar 21, 2010 | 09:16 AM
RSWORDS's Avatar
You need a 12x1.75 BOTTOM tap, not sure how long it needs to be. Maybe BC847 will chime in and let us know....
I would just order teh one from A-1 that way you know for a fact it will work.
Old Mar 21, 2010 | 01:35 PM
BC847's Avatar
A standard threading tap is not the same as a bottoming tap. See image below . . .
Threads all the way to the bottom of the bolt bore are required to accommodate the full length of the stud threads.
Further, chasing of the existing threads is needed as a minimum as the bores under the rocker pedestals are full of oil residue like those at the exhaust side are often coked. There's a lot of mess in there . . . .
A standard length bottoming tap will work just fine (with the head off the block).
Old Mar 21, 2010 | 01:39 PM
RSWORDS's Avatar
Thanks David!
Old Mar 21, 2010 | 10:25 PM
seandonato73's Avatar
just went through all that crap on my turck, i went with ARP tho, still bottemed taped the holes. does A1 tell you to cycle the studs three times before you final tourque the head on? my arms felt like jello till i was done cycleing the studs and final tourqueing them.
Old Mar 25, 2010 | 10:02 AM
freak007's Avatar
Thanks guys... I was aware of the difference between a bottoming tap and a tapered tap. I was just unsure if a standard length tap would be fine or not...
I bought a 12x1.75 bottom tap at NAPA for under $7, sure beats the 20+ that A1 wanted
