fuel PSI gauge help
Old Mar 20, 2010 | 04:24 PM
NCFPD's Avatar
Default fuel PSI gauge help
ok i have a mechanical autometer fuel pis gauge in my pillar pod can some one make a list of parts sizes and types of stuff i will need to hook it up Ie.size type hose fittings and everything basicly thanks for any one that can help
Old Mar 20, 2010 | 04:50 PM
ArizonaRedneck's Avatar
Auto Meter maybe this will give you an idea of what you need
Old Mar 20, 2010 | 06:23 PM
I can get ya a package together.
Old Mar 20, 2010 | 08:25 PM
NCFPD's Avatar
PM me a price
Old Mar 20, 2010 | 10:10 PM
I am uncertain what kind of fuel filter housing a 98 has but I believe it should be very similar to a 99.
Here is an install on a 99 CTD:
So, basically what you need is a fitting to thread into the filter housing (this is a 1/8" npt fitting), and a needle valve, some line (1/8" DOT approved air brake line), and a guage. Obviously, if you use 1/8" line you need 1/8" npt fittings. Also, the fitting at the gauge should be 1/8" npt female. I would also push the 1/8" tubing through larger 1/4" tubing where it passes through the firewall for abrasion resisitance.
I cant give you exact part numbers but it should be too hard to track down the parts. You dont really need to buy a "kit" for this.
Old Mar 20, 2010 | 11:44 PM
Since your running the raptor 150 id recommend our Vulcan Filter to Injection Pump Kit. This will replace everything from the Filter to the VP44 and give you 1/2 or 3/8 line for better flow. It will also include the tapped 90 degree fitting for fuel pressure access. This is a bit more expensive but will net you a few more pounds of fuel pressure.
Old Mar 20, 2010 | 11:46 PM
I did not even see that Luke - good catch.
Old Mar 20, 2010 | 11:49 PM
The only reason I say this is these are very popular with the guys running the Raptors, HPFP or the home brew lift pump setups. Theres quiet a bit of restriction on the stock setup.
Old Mar 21, 2010 | 09:51 PM
NCFPD's Avatar
ok thanks guys helps out alot and i will have to wait to save some money for what you had mintioned luke but i will deff. hit you up so i can get rid of that stock filter
Old Mar 21, 2010 | 10:17 PM
dodge rodder's Avatar
got my fuel tubing kit form Jegs racing and all the connector and fittings are in the tubing
kit. 4AN size
