upgrade
Old Mar 20, 2010 | 11:14 AM
brad2003's Avatar
Default upgrade
i was woundering if anyone makes payment plans on up grading i would like to do my turbo-head studs-a fas pump and injectors
i got a bad head gasket and would like to do it all at once if possable.
Old Mar 20, 2010 | 07:53 PM
dustys24valve's Avatar
your best bet with that is to become really friendly with your local diesel performance shop owner....
Old Mar 23, 2010 | 01:12 PM
brad2003's Avatar
ok so dose someone offer a good stud and head gasket kit. and if so about how much would it run me thanks.
Old Mar 26, 2010 | 12:41 PM
Karls03's Avatar
The payment plan is called VISA Wanna play, gotta pay
ARP makes REAL good fasteners. Many members will say I am smoking crack on this, but if head studs are done ONE AT A TIME, the heads don't have to come off. Remove a bolt, install a stud, torque, go to the next. Some firewall components need to be moved for clearence, but it's do-able.
Old Mar 26, 2010 | 02:12 PM
brad2003's Avatar
well im blowing coolant out the fill cap and i hear its a head gasket so i think id need to chainge it to whats your thoughts
Old Mar 26, 2010 | 05:56 PM
Karls03's Avatar
If you're under 100K, pay your $100 deductible and make a dealership fix it. That motor is under warranty from "turbo to oil pan" for 100K. Other than that, brace for impact, it's gonna sting!
Old Mar 26, 2010 | 09:11 PM
brad2003's Avatar
well they said my warranty was void when i bought it it has the banks big hoss bundle on it and they said its over 5 yrs so i gess i have to take the and see the
ok so i talked to about the only diesel machanice we have close by and it only blows coolant out if its above the lowe line and he said it may not be a problem at all and he is going to run some psi test on the coolant stuff and see what it is
Old Mar 26, 2010 | 10:21 PM
Mdub707's Avatar
Most of the trucks after they get studs and fresh gaskets usually puke a little out until they reach their "happy level" and then seem to stop...
Old Mar 26, 2010 | 10:29 PM
brad2003's Avatar
well i want to thank everyone for ther help
Old Mar 27, 2010 | 01:45 AM
Karls03's Avatar
[QUOTE=brad2003;524740]well they said my warranty was void when i bought it it has the banks big hoss bundle on it and they said its over 5 yrs so i gess i have to take the and see the
[color=grey][size=-2]
Voided warranty because of the Big Hoss Bundle!?! Voided because it is over 5 years old!?! That is SUCH a load of crap! Mine is going to be 8 years old when the 2011s come out and they will keep fixing it until it is at 100,001 miles!
Take out the Six Gun, go to another dealership and put them to work! They won't warranty exhaust or inner-cooler if you have the Techni-Cooler, true, but that has absolutely D!&K to do with the motor/head gaskets. Dealerships are cheap skates and will find any excuse possible to not eat a repair job. Jones West Ford in Reno sold me a truck without a cat (Reno requires smog) and a burned up turbo! All the while swearing up and down it was good to go.
