white smoke
Old Mar 20, 2010 | 04:28 AM
rsexton721's Avatar
Default white smoke
i rember seeing this posted somewhere else but can't find it but my truck runs completly fine at idle and while driving under normal conditions and flooring it from a dead stop most the time but whenever im doing somewhere between 30-50mph it just pours white smoke and i dont have any clue why its doing this anyone have any clue?
Old Mar 20, 2010 | 06:24 PM
dodge rodder's Avatar
it might be way over fueling if its white, or bad turbo
it will be thick black cloud if it is burnt
Old Mar 20, 2010 | 09:17 PM
Begle1's Avatar
Probably not a fueling problem if it's doing it while up to temp; could possibly be a problem with contaminated fuel.
Is the vehicle getting up to temperature?
Are you loosing coolant? Do pressure tests to look for a bad headgasket or a cracked cylinder head.
Could be low compression; do you have excessive blowby?
What year of vehicle are we talking about? Could be EGR if it's an EGR-equipped engine.
White smoke is a sign of fuel that isn't burning because it isn't getting hot enough.
Old Mar 20, 2010 | 10:46 PM
rsexton721's Avatar
its an 06 only has 45000 miles it dosent do it all the time i dont think im loosing any collant (ill have to keep an eye on it) no ecessive blowby and the vehicle is up to temperature when its doing it. ill keep you posted i think it may be the fuel i got diesel somewhere different today then where i normaly get it and it seemed to stop.
Could the temp outside have something to do with it blowing white smoke whe i get on it seems to be doing it more in the morning and at night when its chilly and not so much during the day when its about 70 out
also i wouldnt think it would but could a bad thermostat have something to do with it because my thermostat has been floppy and i thing it is going bad
Old Mar 21, 2010 | 09:08 PM
skinnysfd's Avatar
my old 05 started doing this and it turned out to be a turbo. i took off the air cleaner boots and all and grab the center nut on my turbo and there was a lot of play in it took it to the dealer and they said the bearing was bad which caused the white smoke to pour out when under throttle. i would try to check that maybe???????
Old Mar 22, 2010 | 02:41 AM
rsexton721's Avatar
ill check it hopefully thats what it is since i got a spare one sitting in the garage to steal parts off of
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
