CRANK CASE VENT
Old Mar 20, 2010 | 12:13 AM
redwood logger's Avatar
Default CRANK CASE VENT
can anyone tell me exactly how you get it apart to clean it. dealing with a '93 12v
Old Mar 20, 2010 | 07:21 AM
BC847's Avatar
- Remove the two bolts that hold the lifter valley cover to the side of the engine.
- Flush the crankcase vent baffle with some solvent.
Old Mar 20, 2010 | 07:24 AM
big bad diesel 416's Avatar
Site Sponsor
your talking about the one on the drivers side rear of the block its a PITA
you have to pull the VE the lift pump throttle bracket injector lines its just a real bitch
i had to do mine it developed a bad oil leak right back there and you have to pull the tappet covet off (that's the cover that runs the full length of the block) once its off it will come apart in your hands its just a little plate and what looks like an sos pad to keep some of the oil in i replaced it with one of the silver pads you clean your dished with works fine been running that for the last 10,000 miles go to your parts house and buy a new breather tube too cut the end towards the ground at a 45* angle with the longest part facing the rear of the truck (see pic) you want it to hang down about 3-6 in form the oil pan this makes a vacuum effect and pulls the fumes out of the block
https://www.dieselbombers.com/attach...1&d=1269087790
Old Mar 20, 2010 | 09:41 AM
thanks guys, thats the info i needed. although not good news! thats alot of work to clean something that might be clogged! on the other hand if i dont i risk the chance of blowing out my new rear main seal. now i am wondering if there is any way icould cut the elbow shorter (leaving enough to get a hose on and reach in ther with needle nose pliers and pull out said clogged sos pad to avoid having to take all that stuff off every time it needs to be cleaned.
Old Mar 20, 2010 | 01:41 PM
Site Sponsor
its not something you do with an oil change if your realy woried http://www.dieseltruckresource.com/d....html?t=199914
Old Mar 20, 2010 | 09:06 PM
thanks for all the advice. i did some testing and found the vent to be open so im not going to worry about it. but my new main seal seams like it might be leaking a little already and now there is a leak that developed on the injection pump and if that isnt enough it looks like the heater core just sprung a leak! sO I just went in the house and started drinking!
Old Mar 20, 2010 | 11:29 PM
Site Sponsor
ha ha thats a dodge mines the same way i had to do the RMS twice what a bitch that was
Old Mar 21, 2010 | 10:14 PM
seandonato73's Avatar
hey at least it isn't as bad as what i just went through.... blew the head gasget, found out my stock head was cracked, sent the rad out to get cleaned out... to get a call from the rad shop telling me my rad was junk, so new rad, head studs and 60# springs were on back order till next mounth had to cancel that order and ended up paying out the tail for the stuff at a local diesel/rip off shop. and now i think my water pump may be on it's way out. hell i just put $1500 into the truck! i still love the thing tho
Old Mar 21, 2010 | 10:28 PM
Site Sponsor
dang man that suckes
Old Mar 21, 2010 | 10:35 PM
at least shes all back together now, first time i got to drive her in two weeks, cann't tell you how much i missed it
ish1521
Aug 26, 2015 08:42 PM
Paladin
Jul 26, 2015 03:59 PM
tmcc14
Apr 21, 2015 03:59 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
steves2500diesel
Oct 14, 2014 05:36 PM
